Thread: Jandy Aquapure 1400 SWG codes 172, 182, 185, 186
    Aug 2015
    Weatherford, TX
    1
    Hi All, I am at wits and and I have already replaced most parts of my system. I am not producing chlorine unless I manually (at the box) press and hold in the button to put in boost mode, then I am producing 100% chlorine.
    In the past month I have replaced the SWG cell, the sensor and the back board. I have the PSD306-01 front board, of which I cannot find any replacements at this point. I ran the test from the attached image and the results were:
    Test1: 2.7
    Test2: 74
    Test3: 91
    So those tests seems to be in range. After I hooked the sensor back up I got the following error codes: 172, 182, 185, 186 (yes all of them) I am pretty much done with Jandy, I am thinking of installing a whole new salt generator and just selling off the barely used parts.
    I am now wondering if I got a faulty "new" sensor and should try to get another or just get a whole new system?
    I ran the volts tests on the Front board and it all seems ok. Thoughts ?? Any help?
    ~Steve, 30K gallon in-ground, Jandy Aquapure 1400
    Jun 2011
    Long Beach, CA
    2,781
    Re: Jandy Aquapure 1400 SWG codes 172, 182, 185, 186
    Welcome to TFP!
    All of those error codes point to a bad sensor. Which new sensor model do you have?
