Thread: How much MA to drop the TA
    wjr75's Avatar
    Jun 2013
    IL
    836
    Hello All,
    How much MA would be required over time to drop my TA from 80ppm to 50ppm in a 900 gallon hot tub? I want to add boric acid once the TA gets down to around 50ppm without having to test TA all the time prior.
    Thanks
    Will
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: How much MA to drop the TA
    7 or 8 oz should do it.
