Results 1 to 10 of 10
Thread: pool solar cover causing ph rise
    May 2014
    Inverness Fl
    53
    thought I had read that keeping a cover on at night, would help lower ph, but the opposite is happening, the ph rises. I test all chem with the TF-100, and everything else is OK. But we started to keep the cover on at night to help maintain the temp. better, we have a heater also , I just tested the ph, it was 8.2. Is this normal? The ph has not acted this way before without the cover being on.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Re: pool solar cover causing ph rise
    I've been using a cover for years and don't have a problem with any abnormal pH rise.
    Please add your pools info into your signature as outlined here - - > Pool School - Getting Started
    Do you have a spa attached to the pool ??
    Solar Blanket, Well Water, Borax Added. 76
    May 2014
    Inverness Fl
    53
    don't have a spa--we got 1/4 inch of rain, but that never seemed to raise the ph like this before. I'm really stumped, the solar cover is the only thing we have changed.
    mid 2014 12 X 30 12k gallons IG Plaster\Fl Gem Finish. StaRite\Pentair DE filter. StaRite\Pentair IntelliPro VS Pump. Pentair UltraTemp Heat Pump Unit. Intellichlor IC40 salt system (not up and running yet)
    Very hard well water-no iron. TF-100 Test Kit (the best)
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Rain can cause PH to rise due to aeration of the water. There is no reason I can think of that a solar cover could cause PH rise. What is your TA?
    domct203's Avatar
    Jun 2015
    CT
    3,597
    I use a solar cover every night and have no pH issues at all.
    Can you post a complete set of test results (FC, CC, CYA, pH, TA & CH)?
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    May 2014
    Inverness Fl
    53
    tested this morning 10-2
    FC 6.5
    CC 6.5
    CYA 30-40 never sure what I think I see on this one
    PH 7.5 today added 1 1/2 cups of acid yesterday after seeing the rise
    TA 80
    CH 300
    my pool since last year likes a ph of 7.8 I have brought the TA down a couple of times from being over a 100, and the ph always comes back and settles in at 7.8 stays there forever. thats why this threw me, but there could be another reason I just remembered, I also read I think that using a solar cover at night, to reduce your chlorine by half, which I thought I did, enough, but I guess not. I keep the FC at 5 to 7, and the other day right before this, I noticed that when I put the power in the test beaker (from the tf-100) it was very very red, I knew FC was out of wack, and it was FC 13.5. So I had to let it come down, but could that be the cause of the sharp uptick in the ph.
    May 2014
    SE, Wisconsin
    46
    A couple of things;
    You have listed cc of 6.5 I assume that that is a typo, since fc was also 6.5 if it is not a typo we have a problem.
    The PH test will not be accurate when FC is greater than 10. So on that particular day the results are invalid.
    The FC chlorine loss is from two things, organics and UV light. At night there would be no loss from UV so your cover should not have any bearing at night, Now during the day the cover (if opaque) will definitely lessen chlorine loss when covered.
    Hope this helps
    20,000 gal, 18 x 36 IG Vinyl, 1.5 HP Hayward 2610x152S two speed, Sta-Rite S870 sand filter, Raypak 265,000 BTU P-R26A-EP-C, TF-100 Test Kit
    May 2014
    Inverness Fl
    53
    your right--in my haste to post that-it should have been
    FC 6.5
    CC 0
    TC 6.5
    the high chlorine is definitely why the ph was a bad number then. the cover is opaque, we had left it on during the day, we had several different days we didn't get to swim much, putting the cover right back on, thought I had cut down on the chlorine enough to compensate for not losing much thru the days or at night. 1st time using a cover on the pool, and still getting use to it. didn't cut down enough, even though we were still swimming some, but not enough which is why the Chlorine got so high.
    all this came about because I just started using the cover, testing it with the Pentair Ultra Temp heat unit, to extend the swimming season. 1st time using the heat unit also. pool had never seen the cover on that much, equals less chlorine loss during the day, because the cover would go right back on to help hold the heat put out form the unit.
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,264
    Quote Originally Posted by ryker View Post
    Please advise on when you are adding liquid chlorine and when you are testing for PH? Adding bleach raises PH immediately, but as the chlorine is consumed, PH comes down, and everything is PH Neutral. Are you testing after adding liquid chlorine? Could this be the issue?
    How much does liquid chlorine raise PH for how long?
    You will find much more information if you search the forum on this matter. Thank you.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    mas985's Avatar
    Pleasanton, CA
    11,743
    Did you just start running the SWG but didn't update your sig?
    Mark
