Thread: Jandy Aquapure Ei No Flow
    Jun 2015
    Cedar Park, TX
    12
    Last night the display started displaying No Flow and the red and orange lights alternate flashing on and off. Flow meter reads 62 GPM (per the manual this unit requires a minimum of 40 GPM) and has worked in the past with flow as low as 35 GPM so definitely not a pump flow problem. Salt is at proper level. I shut off the power, removed cell and wires and reattached. Same thing. Cell is only 5 months old and has been working perfectly. Anyone have any ideas? Hoping there is some way of resetting the system other than shutting off power since I have already tried that. Otherwise guessing new cable assembly and if that does not work new board?
    15,000 IG Plaster
    Pentair TR-100 Sand
    Pentair IC40 SWG
    Pentair EasyTouch with ScreenLogic2
    Re: Jandy Aquapure Ei No Flow
    Maybe a bad flow switch.
    Support the site
