Thread: Pentair 3 way valve
    Jun 2014
    Hauppauge, NY
    19
    Pentair 3 way valve
    Is there a way to turn the Common Port off on a Pentair 3 way Valve?
    The way the valve is currently set up I can only do 1 of 3 things
    1. Turn Port 1 Off
    2. Turn Port 2 Off
    3. Turn Port 1 & Port 2 On
    Basically Im looking to turn Port 1 and Port 2 off at the same time
    This is the valve.
    20 x 40 Inground Liner Walled Pool 33,000 Gallons, Hayward DE3620 Filter w/ multiport valve, Hayward SuperPump VS Pump. Stenner Fixed Rate Chlorinating Pump
    38,390
    Re: Pentair 3 way valve
    I think if you pull those pins you can turn the handle and diverter all the way around.
    Jun 2015
    Wildomar, California
    423
    Yes, remove those pins.
