Results 1 to 14 of 14
Thread: Reduce PH Auto Fill Water
    Sep 2015
    Wellington
    25
    I have a large recirculating fountain that has an auto fill device and it is connected to one of my pool return lines . This insures that the fountain always has the proper amount of water and I do not have to treat the fountain for algae etc. It draws approx. 30 gallons/day from the pool water. The swimming pool has an auto-fill connected to the side of the house and since the pool level always looks good - it must be getting approx. 30 gallons/day of tap water.
    The Issue: I have to add about 1+ gallon/week of acid to the pool to keep the PH around 7.6-7.8. I tested the Tap water and the PH is higher than the 8.2 of the test kit. I'm thinking that the added high PH tap water is raising my pool PH? Is there any type of filter device that I could add to my pool auto-fill line that would reduce the PH before it gets to the pool? I have read online that Brita filters lower PH to 6 (source: google) and I wonder if anyone here has any other suggestions? Pool is approx. 18,000 gallons. I would rather not automate Acid since it is so hazardous...
    Thanks!
    Pentair EasyTouch 4, Three 12" Copper Bobe' Scuppers
    Pentiar ScreenLogic Interface w/iPhone App
    Pentair Intelliflo VS Pump, Intellichlor SWG
    Hayward Universal Colorlogic LEDs, Pentair Clean & Clear 200 Filter
    TF Test Kit
    domct203's Avatar
    Jun 2015
    CT
    3,597
    Re: Reduce PH Auto Fill Water
    Hello,
    I would imagine that the volume of fill water in comparison to the volume of your pool would be negligible in raising your pH, and that your pH rise is due to other issues (aeration, high TA, etc).
    pH rise in a pool is not uncommon at all.
    How do you test your pool, and how often?
    210 gallons (30x7) of fill water in an 18000 gallon pool is only about 1% of the total volume.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    30,432
    I am not sure how that would work....do you have a link? Did they mention capacity?
    Jul 2015
    Tempe, AZ
    194
    What's the TA of the pool and fill water?
    John - 16,000 gallon | in ground | pebble | Triton II sand filter | TF100 | speedstir | Hayward Phoenix 2x
    Sep 2015
    Wellington
    25
    I use the TF Test Kit and I have a Pentair SWG. I do a complete test once a week and I check the chlorine and PH every 2 days because I'm trying to get the PH stable - the pool is 2 months old. Today's test results:
    PH - 7.5
    FC - 6.5
    TA - 50 (please read below)
    CYA - 65
    CH - 350 (this was 325 before I started adding Sodium Bicarb)
    Salt - 3200
    I have 3 Bobe' 12" Wide Copper Scuppers and so they aerate the water a lot
    Ta:
    9/17 - 60 - added 42 oz Sodium Bicarb (from Home Depot "Total Alkalinity Increaser" - 100% Sodium Bicarb)
    9/24 - 60 - Not sure why it did not go up since last week? - Added 32 oz Sodium Bicarb
    10/1 - 50 - (tested twice) What is going on? it is like the Sodium Bicarb is reducing my TA?
    I have been adding approx. 1 Gal Acid per week.
    My Tap Water:
    TA - 60
    PH - 8.2+(my test scale maxed out at 8.2)
    What are the odds that the "Total Alkalinity Increaser" was mis-packaged and its an Alkalinity Reducer? I'm afraid to add more for fear of lowering TA further...Should I just get a new bag from another brand? - although now I'm getting concerned that if I keep adding Sodium Bicarb, my Calcium Hardness is going to get too high?
    Brett
    Dom, Good Point on the volume, maybe the tap water is not the issue...
    TF Test Kit
    Sep 2015
    Wellington
    25
    Maybe this is not my issue due to the volume compared to the pool, but here is what I found online in case your curious:
    How to lower ph via brita filter - YouTube
    Brita Filter Water Analysis... Tested LIVE For pH, TDS, And Potentially Harmful Contaminants - YouTube (he indicates it produces PH 6.3, but later PH rises?)
    Dave, do you think I should keep adding Sodium Bicarb or will that make my Calcium Hardness to high? Thanks again!
    TF Test Kit
    Jan 2012
    'burbs of Augusta, Georgia
    7,373
    All that acid is most likely causing the TA to drop. That your pool is only two months old (plaster, I take it?) is also common as the plaster cures for the pH to require acid. Assuming all continues well this may go on for months before leveling out.
    Sep 2015
    Wellington
    25
    Quote Originally Posted by YippeeSkippy View Post
    Should I be worried about increasing the Calcium Hardness by adding more Sodium Bicarb?
    TF Test Kit
    wjr75's Avatar
    Jun 2013
    IL
    836
    If you have new plaster that is probably the cause. When I had my new Pebble Sheen applied a year ago it took 6 gallons of MA in 4 months to keep the ph in range.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    30,432
    I am not aware there is a relationship. Am I overlooking something?
    Mar 2007
    San Rafael, CA USA
    12,082
    Are you using full-strength Muriatic Acid (31.45% Hydrochloric Acid)? If so, then one gallon in 18,000 gallons of pool water will lower the TA by 28 ppm which is substantial. 42+32=74 ounces weight of sodium bicarbonate should have increased the TA by 18 ppm but given the amount of acid you've been adding the net result over one week week would be 18-28 = -10 ppm so a 10 ppm drop in TA. So what you are seeing is not surprising at all. Basically, to maintain the TA level you'd have to add a lot more bicarb given the amount of acid you've been adding. In effect by adding acid+bicarb you are adding carbon dioxide back into your pool (and adding salt as well):
    HCl + NaHCO3 ---> CO2 + H2O + NaCl
    Hydrochloric acid + Sodium Bicarbonate ---> Carbon Dioxide + Water + Salt
    However, this acid+bicarb vicious cycle needs to be broken. If the recirculating fountain is primarily recirculating its own water and is truly only taking 30 gallons/day from the pool so that is all the fill water that is then getting into your pool, then that isn't enough to be causing the pH rise. It does seem that the pH rise if from a combination of the new plaster and the aeration of your pool water from the scuppers.
    Quote Originally Posted by BPet View Post
    While this aeration certainly doesn't help, the amount of aeration at the low TA level will be low. Specifically, with your numbers when the TA was at 50 ppm, the pH would stop rising completely at 7.8 if this were only from carbon dioxide outgassing. So I suspect that the new plaster is contributing and the good news is that if you don't see any rise in CH then it means that the plaster surface is hardening "in-place" as follows.
    Ca(OH)2 + CO2(aq) ---> CaCO3 + H2O
    Calcium Hydroxide + Carbon Dioxide ---> Calcium Carbonate + Water
    In other words, such plaster hardening looks exactly the same as carbon dioxide outgassing in terms of the effects on water chemistry. The concern I have is that at your current levels your saturation index is at -0.6 and this is with fairly new plaster. Unless you have a metals problem where staining would be a risk, I'd keep your pH higher at 7.8 (i.e. lower it from 8.0 to 7.7 or 7.8, not to 7.5) and maintain your TA at around 60 ppm (keeping it lower due to your outgassing from the scuppers) and eventually as things settle down with a slower pH rise you'll want your CH to be higher closer to 400-450 so that you can maintain the lower 60 ppm TA. I would not try and keep your pH at 7.5 since that will just exacerbate the outgassing problem and risks dissolving of pool plaster (calcium carbonate).
    If you aren't using 50 ppm Borates, then adding them would help slow down the rate of pH rise though they may not change the amount of acid you need to add. Why don't you try the adjustments I suggest above first to see how things go. You want your pool plaster to harden so if anything you'd want a higher saturation index to speed that up (so a higher TA), but with your scuppers that would just have the pH go up higher. Is there any way for you to (temporarily) turn off water flow through those scuppers, at least during this phase of plaster hardening?
    Sep 2015
    Wellington
    25
    Chem Geek, thank you so much for your detailed reply! I will aim to keep the PH at 7.8 and maintain my TA at 60ppm.
    Yes, I can turn off my scuppers. How long would you guess it would take for the plaster to harden before I can turn them back on?
    Thanks!
    TF Test Kit
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,212
    Thanks!
    Most new plaster pool owners see pH rise for the first full year. But, as the year goes on the rise slows.
    Support the site
    Jaimslaw's Avatar
    Jun 2015
    San Diego, CA
    300
    Quote Originally Posted by tim5055 View Post
    Is is true that ph rise levels will not be affected by the type of finish, e.g., a mini pebble finish or even a micro pebble,finish? At first blush, one might think its possible the given the ratio of aggregate to plaster, there could be a difference in ph rise levels, tho me thinks this is not the case.
    Pool: 13k gal. in-ground; Stonescape Mini Pebble - Tropics Blue; Connected Spa - dual spill-over; Aqua Rite T-15 SWCG; AquaLogic PS-4 Automation; Sta-Rite DE Filter; Sta-Rite Max-e-Therm 400k BTU pool heater; Intellifo 2-VST Pump; Stenner 45mp2(25psi/10gpd) acid injection; Bulbwizard color LED pool lights; Poolvergnuegen 2 wheel side suction cleaner; FAFCO rooftop solar. TF-100 w/ speed stir.
