Thread: Timer motor not working
    Oct 2015
    Alpharetta
    2
    I am an idiot when it comes to electricity and can only duplicate what I've previously disasembled. Just replaced a T104R timer with a T104M, both of which are supposedly 240v timers, but when I check the voltage, it's only 110. The T104R worked fine for 15 years. Everything works manually but the timer does not. Would I be crazy if I said it will work briefly but then stopped for no reason. I took my first purchased T104M back due to the same reason. Now I'm embarassed because this second one is doing the same thing. Off this 30 amp breaker is white, green and one black wire. Do I have the wrong timer?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Timer motor not working
    If the power is 240, then you should have 240V between the black and white wires, and 120V between the green and the other two wires.
    A common mistake made on these is to reverse the line and load. The clock will run when the switch is on, but as soon as it shuts off it stops.
    ps0303's Avatar
    Jul 2011
    FL
    3,684
    Did you follow this wiring diagram when you re wired the new timer? Terminals 1 & 3 are your line wires. 2&4 are the loads i.e pump/equipment.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Oct 2015
    Alpharetta
    2
    Just studied up on understanding line and load. I'll try again this evening, thanks
