Results 1 to 8 of 8
Thread: New build- Gunite shell depth too shallow
    Sep 2015
    Winter Garden, Florida
    2
    Hello all,
    We have been reading this site for months watching builds and soaking in the advice and opinions before finally starting our own build. I do have a question and would appreciate any opinions or advice offered.
    The pool depth is to be 3.5' in the shallow end and 5.5' in the deep end. In the shallow end, it is only 41 inches from floor to top of the bond beam.
    Assuming the plaster (quartzscapes) will raise the floor level also, the 41" bond beam height would not appear to allow for a 42" water level. I believe the bond beam should have been 45" high, correct?
    When I brought this to PB's attention, he said he would "raise the tiles"to get "the water level I want".
    It isn't just the level I want, it is the water level in the contract.
    Wouldn't this be measured by the PB instead of me being the one to notice?
    The coping will be cantilever concrete.
    Does "raising the tiles" sound like a reasonable solution?
    I can't picture how that would work.
    If not reasonable, how would you approach it?
    I do like my PB, and he has a great reputation and was referrrd to me by a friend.
    Any advice or opinion would be much appreciated.
    Thank you much!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,406
    Re: New build- Gunite shell depth too shallow
    The water level should be in the middle of the skimmer box.................That allows for the best skimming of the pool...........too low and your pump will suck air in...........too high and the stuff on top of the water will not go into the skimmer basket.
    Raising the tile will have NOTHING to do with the water level. It is all about the skimmer box.
    I hope this helps. Let us know how he answers this.
    Kim
    Oh and do NOT allow anymore work on the pool until this is fixed or you have the answers you want.............
    domct203's Avatar
    Jun 2015
    CT
    3,577
    Kim is on point here, don't let them proceed until this is sorted.
    Sounds like the pool was dug for a 3' shallow end. Can you get a measurement to the center of the skimmer box?
    To me, your PB's response is BS. Raising the waterline in the shallow end will also raise it in the deep end. Either way, it's all about the skimmer box as Kim mentioned.
    Dom
    Edit: Where are my manners, welcome to TFP!
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Helen203's Avatar
    Jul 2015
    Annapolis, MD
    819
    I'm not sure about your contract, but ours was non-specific about how the depth is calculated. The deep spot in our sport pool under construction is only 5'4" at mid-point to the skimmer, 5'7" to the top of the bond beam. We asked for 5'6". We thought after the excavation and steel that we'd hit 5'6" mid-skimmer with gunite, but the gunite crew went a little heavy. We shrugged it off -- its only 2 inches.
    My Pool Build (2015): inground 12K gals gunite/plaster pool, SWG, 2-speed pump, cartridge filter, gas heater, and Dolphon s300i. TF-100 Test Kit w/ Speed Stir
    Aug 2014
    NJ
    435
    Sounds like they already poured the gunite so I'm not sure how they are going to fix it
    1200 Sq Ft 41,000 Gal. Gunite, JANDY SVRS VS pump, JANDY JXI 400,000 BTU, Polaris 280 w/ 3/4 BP, Rockwall and Grotto (w/6 jets and blower), 2 JANDY Lam Jets, 2 LED Bubblers, 5 Ledlights, AQUALINK P16 RS, 90% Quartz, SWF 185 GMP BP, SWF 125 BP, Levelor K1100 Autofill, AP Digital SWG, 2 skim and 5 returns, and mostly 3 inch piping
    Sep 2015
    2
    Hello all,
    Thank you for the responses.
    I did talk with the PB today, and he explained what he planned to do.
    He said they have done this many times before and that it wouldn't be an issue.
    They are going to raise the tile a few inches (so the top of the tile will not be flush with the top of the bond beam).
    There will be cement behind the tiles, and he said that the deck itself will be the same thickness...but will be raised a couple of inches higher.
    He said the deck being raised wouldn't be an issue since our deck is going up to the house and not connecting to an existing lanai.
    The skimmer is not installed yet, as he said it is installed by the tile guy/s.
    he said it would be adjusted similar to how bond beams are if they are not level all the way around.
    I have included a couple of pics to see the setup.
    Does any of this sound reasonable?
    Thanks again, any thoughts appreciated.
    Helen203's Avatar
    Jul 2015
    Annapolis, MD
    819
    That is interesting, don't see why it wouldn't work, but it will be challenging. Be sure that the addl concrete is anchored into the existing bond beam so you don't get horizontal cracks. And double-check your warranties. Pls let us know how it goes!!!
    Jul 2012
    Tallahassee, FL
    30,406
    "the deck itself will be the same thickness...but will be raised a couple of inches higher."
    So how is he going to raise the deck? Is he going to raise the whole deck from the pool to the house? what is the deck going to be made of?
    My worry is that that whatever they use to raise it can settle and cause problems in the future. I also worry that if they only raise it by the pool that could cause water to flow towards the house.
    Just throwing things out there so you can ask and get solid answers.
    IF they do it right it could work. Too bad they did not dig, rebar and shoot gunite correct from the start
    Kim
