Thread: Pump not completely priming, replacement impeller, diffuser, seals didnt fix
    Sta rite pump; seems to be working fine. When I broke down the pump to check the inside, there was wear to the seals, impeller showed some hair line cracking, so I decided to replace the inner parts and seals. I had already checked for leaking on the intake side and found nothing. After part replacement, no change. I will get water flow through the pump but at no significant pressure or volume. When I turn the pump off, the pump basket housing is pretty much full of water. Water level drops down to about 1/2 as soon as I start the pump. As the pump runs, air is collecting at the top of the filter housing as evidence by multiple openings of the bleed valve over the course of about 10 minutes. Seems like there has to be a leeak on the suction side...is it time to start digging to check the pipe underground? Or am I missing something obvious? Any thoughts would be appreciated.
    Thanks
    Bob W; 30,000 gal inground, about 30 years old
    1 1/2 HP 2 speed pump; single skimmer opening and bottom drain; single ball valve controlling both
    Inground spa; about 400 gallons; 2 HP StaRite pump, Jacuzzi cartridge filter, Hayward propane heater
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    Re: Pump not completely priming, replacement impeller, diffuser, seals didnt fix
    are you getting a vortex in the skimmer when it's on?
    is your weir door stuck?
    Dolphin E10 Cleaning Robot.
    Jun 2015
    Australia
    10
    Dont dig until you have checked the obvious things. Replace the pump lid o'ring and the barrel union o'ring. You might even find it is something like a hairline crack in the pump lid itself.
    Have you noticed a increased loss in water?
    I know it seems a little insulting but i have been doing this for years so please check your water level is high enough over the skimmer box. You would be amazed at how many people miss this seemingly basic thing.
    No pool, i am just here to help.
    All good questions. New o ring on the pump housing lid. Even tried a spare lid and o ring...no change. No vortex or stuck weir in/on the skimmer. No water loss, which would indicate no leak on the suction side below the water line. Added water to an above normal level before any of the other actions taken. So, new impeller, new seals and o rings, no signs of air leakage at the unions or fittings (via a "hose test" to see if water over the joints made a difference). I have not replaced the o ring on the union as I do not have one handy and live an hour away from a pool store. But I did run water over the joint. Could an obstruction in the suction line cause these symptoms? I would think that that there would be low flow, but no presence of air leaking in and getting to the filter housing...
    Thanks so much for your responses. This thing is just making me a bit crazy!
    Oct 2015
    Phoenix
    15
    How old is pump lid can you see through it?
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    Quote Originally Posted by valuator1956 View Post
    Absolutely it could.
    Do you have a main drain? is the valve to it open?
    Try closing that and using the skimmer only. test
    If it persists...close the skimmer and open the main drain only.
    see what happens.
    if it goes away with one of them, yes you have an obstruction.
