Thread: Using single speed pump to drain to waste
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    I have a dedicated single speed pump for a waterfall, 1.5hp 3400RPM.
    My filter valve has no drain to waste option, so I need to drain from a standard hose valve attached to either pump.
    I turned off the valve for the waterfall and hooked the hose up, but there was not a lot of pressure coming from the hose, but a TON of pressure coming out of the return.
    If I shut off both the waterfall and the return, will there be too much pressure to the point of risking damage since the only outlet is a small garden hose?
    Helpful Links: Pool Chemistry 101 - Recommended Levels - Recommended Chemicals - FC/CYA Chart - SLAM Instructions - Pool Math
    Test Kits:
    TF-100 - Taylor K2006 - SpeedStir Upgrade - Taylor K-1766 Salt Test
    My Pool:
    28k IG built May 2015 - Autopilot SWG - Pentair VS Pump/DE Filter/Heat Pump
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Using single speed pump to drain to waste
    I'm not sure what kind of valve you have to control flow to the return(s) but if you can slightly close the valve to reduce flow, maybe you can get more flow from the hose.
    Isolated Spa - 345 Gallons
