Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: pool motor acting up
    Spiccolli's Avatar
    May 2012
    Gold Canyon, AZ
    63
    Hello, so I have this Emerson ESQ1102 Square Flange Pool and Spa Motor 1 HP. its quite a few years old. I replaced the bearings on it about 4 years ago. It has been working fine since. nice and quiet.
    This morning, the water in the pool was barely moving, but the pump/motor was on and sounded fine. The pump had prime, just no pressure.
    I shut off the pump at the panel and the motor wound down very slowly. It normally shuts off instantly as I'm sure you know.
    Any ideas as to what the problem is? Thanks for any help!!!
    1992 15X30 14000 Gal IG plaster, Pentair 011018 - Intelliflo VS Pump with Timer, 350 lb Sta-rite hrpb30 sand (yeah, the 32-bolt clamshell)
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,105
    Re: pool motor acting up
    Sounds like something is stuck in the suction end. What does your pressure gauge read? It is higher or lower than normal?
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Spiccolli's Avatar
    May 2012
    Gold Canyon, AZ
    63
    pressure is 0 - normally about 16.
    when something was stuck in the past, the pump is much louder, and sucking a bit of air.
    not louder today, and not sucking any air.
    what worries me is the motor winding down when the pump is shut off - that's not right.
    i believe the motor is busted - just don't know what is broke, if i can fix it with parts, or what
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,105
    I wonder if the pump impeller has separated from the motor. Can you see the impeller inside the pump basket area?
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    ^^sounds like you said, impeller fell off.
    Dolphin E10 Cleaning Robot.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,105
    I'm not sure how they are connected, but I wouldn't think it would actually be in the basket area. I know that if I take out my basket I can see a few of the blades of the impeller.
    Spiccolli's Avatar
    May 2012
    Gold Canyon, AZ
    63
    @pabeader @borjis I can't see the impeller from the basket area, nor can i reach it with fingers to feel it.
    Even if it did become separated - would that explain the long wind-down of the motor?
    I guess I'll just have to take the whole thing apart and see if something is obviously broken. If I can't figure it out, I'll probly take the motor to a rebuild shop and see what they say.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,105
    Yes it would. No resistance to the motor spinning. The pumps are usually pretty snug and will slow the motor pretty quickly.
    Spiccolli's Avatar
    May 2012
    Gold Canyon, AZ
    63
    So you guys were right again, for the most part. The impeller didn't exactly fall off, the motor shaft is completely broken. Every seal is trashed, and there is a hunk of shaft left in the impeller.
    Thanks for the suggestions! Guess I'm gonna price out a new motor, impeller, and a full seal kit.
    Think there was any way this could have been prevented??
    That's very unusual. I have never seen a motor shaft break. Can you post a picture?
    Support the site
    Spiccolli's Avatar
    May 2012
    Gold Canyon, AZ
    63
    Sure. Here's. The impeller.
    I tried to use one of those back out bits to remove the piece of the shaft , but no luck.
    Here's the motor end
    Very odd. I have never seen that happen. Motor shafts are usually high quality stainless steel.
    I would suspect that there were multiple problems like a leaky seal and a very corrosive environment, perhaps from trichlor or acid exposure.
    Support the site
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,105
    How do you chlorinate?
    Spiccolli's Avatar
    May 2012
    Gold Canyon, AZ
    63
    10% liquid near a jet
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,105
    Good deal. I was afraid you were going to say puck dropped in pump basket!!
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    WOW dude!!
    If I had to guess I'd say the motor is VERY old and was salt chlorinated and that a seal broke and
    was run with a leak for years and years.
    Can't figure how else it would get that rusted.
    one for the books!
    Spiccolli's Avatar
    May 2012
    Gold Canyon, AZ
    63
    Quote Originally Posted by pabeader View Post
    lol, nope. i have learned a few things from this AWESOME site.
    Spiccolli's Avatar
    May 2012
    Gold Canyon, AZ
    63
    So went to price out a motor and seal kit and impeller. over 400. i know i could save at least a third if i price it out and have it shipped, but instead, i went for a Pentair 011018 - Intelliflo VS Pump with Timer. all told, after install was $1200.
    15% off, 15% off installation, $50 rebate (dunno what for), $100 electric co rebate. What got me is the amount i will save in electric and the fact that it has a 5 year warranty. I think it will pay for more than itself within that 5 years.
    think i did OK?
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    not bad...did they include a surge protector? you definitely want that with a vs pump (I learned yesterday)
  20. Back To Top    #20
    Spiccolli's Avatar
    May 2012
    Gold Canyon, AZ
    63
    They didn't say anything about a surge protector. Why would you need one for a vs pump versus a ss pump? what happened to yours borjis?
