Results 1 to 8 of 8
Thread: SWG testing
    kkpjm's Avatar
    May 2011
    Quakertown PA
    41
    SWG testing
    Is there any way to test a Zodiac LM3 cell? Mine is at the end of it's 8th season and we've never had any problems. This summer it seems like it just wouldn't keep up. There's plenty of cloudy output at the front end, so it looks like there is definitely chlorine gas being generated. There is no buildup on the cell plates or anywhere else. I don't want to spend $400 if I don't have to...and convincing SWMBO that it's needed will be a tough conversation. Leslie's in town will check some cells, but not a Zodiac. (Not sure I would trust them with the test anyway, given that the tech said I had TDS levels too high, even after I told him it was a salt pool...he said that salt wasn't a dissolved solid. I had brought a sample in to check CYA since my test stuff was depleted)
    On the other hand, could it be that there's just enough algae in there that the SWG is just barely staying ahead of it? FC seems to be hovering between 1 and 2 even with the SWG set high. Occasional cloudiness is quickly stopped by a gallon or two of bleach.
    Thanks in advance for the help or advice. Pool is being closed next week so the algae problem will go away until next spring...maybe I get away with doing nothing!
    20x44x8 Cardinal vinyl IGP, 33000 gal, 2 hp Mustang, 60 SF CrystalWater DE, Zodiac LM3 SWG
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,511
    Re: SWG testing
    One thing you can do is take a sample away from any return and then take another sample directly out of a return. Compare the FC in both samples. The sample out of the return should be noticeable higher than the other one. Of course you have to ensure your SWG is set to 100% or ensure that is supposed to be producing at the time of the test.
    Jun 2011
    Long Beach, CA
    2,788
    Re: SWG testing
    It sure sounds like you have a small algae problem which is preventing the FC from rising. The best method to check this is to do an OCLT. Raise the FC to around 10 with bleach and run the test.
    To help further we need test results.
    Re: SWG testing
    Man... If that guy says salt is not a dissolved solid I wonder how much money he has cost all the customers he deals with. He is either a total buffoon or a ruthless scammer.
    12K IG SWG Pool
    In the Swamp
    Always full of leaves
    domct203's Avatar
    Jun 2015
    CT
    3,589
    Re: SWG testing
    Quote Originally Posted by ping View Post
    +1, sounds like the start of an algae bloom, especially if manual chlorine additions clear up the pool.
    An OCLT is in order
    be sure to turn off the SWG for the OCLT.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    kkpjm's Avatar
    May 2011
    Quakertown PA
    41
    Re: SWG testing
    Kinda what I was hoping everyone would say...and what I thought as well. I will do an OCLT, for sure. But back to the SWG...depending on who you ask, I've gotten answers on cell life anywhere from 5 years to 10 years. Should I put a new cell in the budget for next year? It sure looks fine to me...never any buildup and there is always a cloud of Cl gas at the front of the unit...
    As usual, thanks for the quick and honest answers.
    Jun 2011
    Long Beach, CA
    2,788
    Re: SWG testing
    List your location. Someone with a short swim season will get more years than someone with their pool open year round. The pool's chemistry will also determine how long the cell will last.
    Your cell might be on its last legs but no one can tell you for sure.
    An OCLT will determine if you are battling algae or not.
    kkpjm's Avatar
    May 2011
    Quakertown PA
    41
    Re: SWG testing
    Southeast Pennsylvania...
