Thread: TF-100 Question
    Aug 2015
    Plano, TX
    217
    TF-100 Question
    Does anyone know what exactly the TF-100's CH reagents test for?
    Is it just calcium (without magnesium)?
    Is it total hardness (as CaCO3)?
    Curtis- 20k gallon IG gunnite/plaster with hot tub/waterfall and "grotto"
    All Jandy equipment: 60sqft DE filter - 399k btu natural gas heater - Stealth pumps - iAquaLink RS8.
    Polaris 9400 on patrol.
    TF-100 in da house/TFP method in effect: FC=4-6, pH=7.5, TA=80, CH=250, CYA=50, Borate=50, CSI=-0.21
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: TF-100 Question
    It's testing only calcium hardness, as dissolved CaCO3. The R-0010 reagent prevents Magnesium interference.
    Extended Test Kit Directions
    Isolated Spa - 345 Gallons
    Aug 2015
    Plano, TX
    217
    Re: TF-100 Question
    Isn't CaCO3 an expression of the concentration of hardness ions in terms of their equivalent value of calcium carbonate? If so, wouldn't that include magnesium ions as well? If this is the case, I don't think this could would give an accurate count of calcium ions alone.
