Thread: How to select a heater for my little pool
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Question How to select a heater for my little pool
    I would like help deciding on a replacement heater for my little pool. I would prefer nat. gas. I would really like to use the pool year round. Pool temp would be best at around 80-85. Hotter is better but not required.
    nat. gas cost is .36 per therm
    electric is .10 per kW
    Thoughts?
    I will be doing the install myself and the current heater is nat. gas.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    38,251
    Re: How to select a heater for my little pool
    A larger heater will heat your water faster using basically the same amount of gas that a smaller heater would.
    Raypak seems to get very positive reviews.
    So, I would suggest the largest Raypak you can afford and that your gas line will support. Although given the size of your pool, there is probably not much of a need to go bigger than 250k BTU ... assuming you are not going to be looking to raise the temp many degrees very quickly.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Thoughts/experiences with Raypak 009216?
    ps0303's Avatar
    Jul 2011
    FL
    3,684
    I sell and install lots of Raypak/Rheem units a year. They are the best unit on the market today. The unit you mention is the 200K BTU unit and is good but I would consider going up a model and at least getting the 266K BTU unit, 009217. Hardly much more in cost, maybe $150 difference, and it would heat your pool faster. For $150 more, it's worth it.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Thanks for the idea! I found that model with free shipping, so less then the first one I was looking at...
    ps0303's Avatar
    Jul 2011
    FL
    3,684
    See, bigger unit for less $$$.
    Enjoy!
    Paul
