Thread: Blowing out the lines!
    Jan 2015
    Stillwater, OK
    10
    Hello all,
    I have had quite the journey scouring the internet to determine if my air compressor will work for blowing out my lines. It seems like both HP and capacity are important. Some people state 5 gallons, others state at least 2 HP. Others say smaller is fine. Others say the compressor must be "good".
    Are there guidelines for determining if your air compressor is "good" enough. Mine is a pancake compressor, 150 psi 6 gallon capacity with .8 HP. Will this work for me? Or is this something that we just have to try and see if we are successful at blowing out the lines? What do we set the regulator to when blowing out the lines? Are there any ways we can make sure the lines are blown out correctly, especially the return lines if they are remaining underwater?
    Sorry if this has been asked before, but I have been really confused about this topic. Hopefully others have as well that are new at this, and the experts here can provide us with some direction! Thank you!
    Best,
    Scott
    22,000 gallon in ground vinyl, Pentair FNS36 DE filter 36sqft, Jandy FHPM1.5 FloPro Medium Head 1-1/2HP Up-Rated Single Speed Pool Pump
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Blowing out the lines!
    Both a shop-vac and a compressor can be successful at blowing out lines, but it's a matter of pressure and volume. A shop vac is good at volume, bad at pressure. A compressor is good at pressure, bad at volume. You need a fair amount of both to blow out lines, especially main drains. The only way to know if your compressor works is to try it. When you do try it, I would aim for setting the PSI at 30 or less.
    Every pool has different lengths and sizing of PVC plumbing meaning a different volume of plumbing to evacuate so it's hard to say if your compressor will work. A cyclone blower designed to blow out pool lines will have the greatest chance of success and would be practically guaranteed to work as it's specifically designed to blow out pool lines with high volume and moderate pressure... but they are a "uni-tasker" and cost $300.
    Isolated Spa - 345 Gallons
    I have the exact same specs on my compressor and I'm wondering if it will work.
    Cincinnati OH, 20K Vinyl IG rect. 16x36, Hayward Super II pump with Hayward 60 GPM sand filter, Hayward H150 heater, space age blue solar cover, one skimmer and one deep end drain, two returns, makeshift fountain on one return for aeration. TF100 test kit.
    Based on my calcs it seems like a normal pancake would do. Do you have any suggestions of where to find adapters to hook up the compressor directly to the main drain line at the shot of valve?
    Feb 2014
    Central Minnesota
    5,080
    Folks who use compressors generally just use a fitting that goes into the drain hole at the base of the pump basket. A properly sized NPT quick connect will screw into the drain plug hole.
    May 2013
    Long Island NY
    419
    Quote Originally Posted by sjdavis2 View Post
    Hello all,
    Best,
    Scott
    I have the same compressor and it works fine. Been using it the last 5 yrs.
    Look on page 5. How I blow out lines with a small compressor.
    19,000 gal - Vinyl IG - Sand filter -1.5hp. - Taylor k 2006 - Loop Loc cover
