Results 1 to 7 of 7
Thread: Average daily chlorine usage
    Richie Rich's Avatar
    Jul 2015
    Riverside, CA or Lake Havasu, AZ
    69
    I've been trying to do the TFPC method since my pool was done 8/21...it's about 15000 gallons and I'm pretty much adding around 2 gallons of 10% chlorine a week on average and about 1/4 gallon of acid. The water is crystal clear, but is this pretty average for daily chlorine consumption?
    Pool Build Finished 08/21/15
    17x30 IG Gunite pool/7' spa with gray plaster filled with city water
    Pentair VS 3 hp (pool guy set to run from 0600-1400)
    Pentair 420
    Pentair 400k heater
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Re: Average daily chlorine usage
    What is your daily FC loss? Between 2-3 is considered normal...
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    You also must consider that you finished your pool in the hottest part of the summer when chlorine need is often highest. As the weather cools you should see a lessening of chlorine use.
    Just keep testing and treating as needed. If your chlorine requirements increase you may need to run an Overnight Chlorine Loss Test (OCLT- directions in Pool School)
    As to the acid- with a new gunnite pool you'll be dealing with pH rise as the surface cures. It can take months. Then it won't be so much anymore.
    Mar 2007
    San Rafael, CA USA
    12,082
    2 gallons of 10% chlorinating liquid in 15,000 gallons is 13.3 ppm FC so that's 1.9 ppm FC so that is actually on the low-end of the typical 2-3 ppm FC (some are lower, especially if they have pool covers, and some are higher, but many are in the 2-3 range).
    Jul 2015
    69
    Quote Originally Posted by chem geek View Post
    Thank you chem geek...
    Pentair 420
    Pentair 400k heater
    EvanWilliams's Avatar
    Sep 2015
    Plano,Texas
    28
    my pool is same size and that's about what I use. My CYA is around 40
    IG: 15000 Gal. Plaster. DE. 1992. Spa. Pump----(Will check brand and update). Heater. TF-100 Kit w Speedstir
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Same here, maybe slightly less. I've been auto dispensing with Stenner at 24 oz. per day, and FC has stayed above 5 for past 2 months. I dump in about 1/2 gallon a week of acid, pH seems to drift to 7.8-8 pretty fast. My pool is 75% shaded, so loss is much less than direct sun. Not sure why I need to much acid, 8 year old pool with pebble finish. CYA 40.
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
