Results 1 to 7 of 7
Thread: IAqualink & JVA Setup
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    I have a total of 4 actuators setup, return, suction, solar, and cleaner. Is it possible to add more to the system? I want to add one more to open a valve for draing water. The plug for the jva have 3 pin, i do have the aux which are 2 pin connectors. Thank you
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    Aug 2015
    Plano, TX
    217
    Re: IAqualink & JVA Setup
    You can control as many devices as you have number of aux (2 pin) outputs. These are relay outputs only though, low current. You may need to add additional relays. For example: my panel is an RS8 but they only installed 4 relays so I had to add a few when I hooked up my landscape lights.
    Curtis- 20k gallon IG gunnite/plaster with hot tub/waterfall and "grotto"
    All Jandy equipment: 60sqft DE filter - 399k btu natural gas heater - Stealth pumps - iAquaLink RS8.
    Polaris 9400 on patrol.
    TF-100 in da house/TFP method in effect: FC=4-6, pH=7.5, TA=80, CH=250, CYA=50, Borate=50, CSI=-0.21
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    I have the rs8 also, just dont see how you would or where you would connect the 3 pin connector. I know that 2 of the wires are clockwise and counterclockwise, and 1 the ground.
    Autopilot SWG
    Aug 2015
    Plano, TX
    217
    Sounds like you should hire someone. You could do a lot of damage to yourself and your equipment. It's not just plug and play.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Well most of it was just logic, like installing the Jandy vsp, the Controler, Autopilot swg, and 7 Fafco 4 x 10 solar panels. I wouldn't say plug and play, but not rocket science. Thanks to TFP and the help here...
    Autopilot SWG
    Aug 2015
    Plano, TX
    217
    Did you get it working?
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    I spoke to tech from Zodiac, they sell a jva board that will give you more jva connections. Item #5254, which plugs into aux, then the board has a aux & jva connections.
    Autopilot SWG
