Results 1 to 7 of 7
Thread: Which sand for Triton II?
    May 2015
    Tempe/Az
    12
    I'm changing the sand in my Triton II and I'm struggling to find sand which meets the requirements from the owners manual:
    * Sand to be No. 20 standard silica (uniformity coefficient not greater than 1.75) .018-.020 in diameter particle size.
    Home Depot/Lowes sells 'Quikrete' which appears outside of that range "US Sieve Size 20-40, Particle size (0.85-0.425 mm)"
    Leslie's only seems to sell Zeolite
    Any suggestions what to do? Do I really need to worry about this?
    Thanks
    19k IG Pebble Tec, SWG Hayward Aqua Rite, Pentair Triton II Sand Filter, 3HP EVSS3-NS Motor, Tempe AZ
    May 2015
    Tempe/Az
    12
    Re: Which sand for Triton II?
    I just found the Aqua Quarts #20 at Ace's which is $12 for 50lb. More expensive than Quikrete ($7) but appears to be what the manual is asking for...
    Jul 2015
    Tempe, AZ
    194
    I read a review somewhere that the quikrete pool sand was not graded correctly for pool sand. That could have been an isolated local problem as that stuff is probably manufactured and bagged regionally.
    John - 16,000 gallon | in ground | pebble | Triton II sand filter | TF100 | speedstir | Hayward Phoenix 2x
    Jun 2015
    Wildomar, California
    423
    You should use #20 play sand. The Quickcrete brand wasn't effective at al I got that at Lowes.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    DO NOT USE PLAY SAND!!!!! GO WITHOUT BEFORE USING IT!!
    I sure hope you heard that. Play sand is NOT made the same as pool filter sand. We had a cloudy pool go for months before it was found to have play sand in the filter.
    I PM'd tetlee. I sure hope they get the message before they fill their filter with the wrong stuff!!
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    You want the correct grade of sand for the filter. #20 silica sand is the standard for sand filters. Play sand is usually not labeled by grade and it is best to just avoid it. Quickcrete bags labeled as pool sand have performed inconsistently by reports on our forum. Why that is the case we don't know, but for that reason I would look for a different brand of pool filter sand if there is one available.
    Love TFP? Become a
    TFP Supporter!
    Feb 2015
    Chandler AZ
    927
    Since the OP is in Tempe AZ, maybe a short drive to Corson's A&M or NPS would result in a better grade of sand for the pool filter. Both should have it in stock or can get enough within a day - Call them first for price and stock on hand.
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
