Results 1 to 10 of 10
Thread: Clayton-Lambert Vac Plate?
    NCSU's Avatar
    Sep 2015
    Goldsboro, NC
    5
    Hello, I am a proud first time homeowner with an ancient IG pool a wise man would have filled in; maybe I'm as lacking for wisdom as I am for cash now because I didn't fill it in and now I'm in too deep (no pun intended). Anyway, I would like to vacuum my pool using a skimmer vac plate adapter so that my skimmer basket catches most of the larger debris. The problem I am having is that my skimmer is some antique called a Clayton-Lambert SS. Is anyone aware of a Clayton-Lambert adapter? Or any rectangular shaped adapter which would work for this skimmer?
    37"8' x 19"6' rectangle shaped, vinyl liner, in-ground pool
    Gregory C's Avatar
    Jul 2015
    Central Indiana
    33
    Re: Clayton-Lambert Vac Plate?
    Not sure if I understand fully - are you looking for a square adapter to fit onto your existing square skimmer basket? Or are you looking for a round adapter that fits onto your existing square skimmer basket? Both for the purposes of using a vacuum.
    Have you tried Hayward and/or Clayton-Lambert parts?
    In ground rectangle pool / 20' x 40' / Fresh Water / GLI vinyl liner (replaced July 2014) / 33,271 gallons & 9 ounces / Hayward Sand Filter Model S - 200 / Hayward Super Pump 1.50 HP (replaced July 2015) TF 50 test kit
    Jul 2012
    Cary, NC (Raleigh)
    69
    Sorry I can't help you out either....but Go Pack.
    18x30 Freeform In-ground Vinyl Lined. 11,500 gallons.
    4 returns, 2 skimmers, 2 main drains.
    Hayward TriStar 1hp 2-Speed Pump. Hayward S244T Filter.Hayward Goldline Panel + SWG.
    Polaris 280 cleaner. AquaComfort 75k BTU Heatpump
    TF-100
    NCSU's Avatar
    Sep 2015
    Goldsboro, NC
    5
    Quote Originally Posted by Gregory C View Post
    Thank you kindly for your response. I assumed since the skimmer basket is rectangular shaped, the adapter would need to be likewise rectangular in shape. Is that not the case? How would a round (or any other shaped) adapter form a seal over the skimmer basket to create the suction needed? At the end of the day, I am merely looking to vacuum my pool using the skimmer basket to catch the debris so whatever shape of the adapter is okay with me as long as it works.
    I haven't found a Hayward adapter in the rectangular shape I need; if anyone knows of one, that may be what I am looking for. I have searched for hours on end & have not been able to find a C-L adapter of any shape.
    NCSU's Avatar
    Sep 2015
    Goldsboro, NC
    5
    Quote Originally Posted by blbncsu View Post
    Go Pack!
    NCSU's Avatar
    Sep 2015
    Goldsboro, NC
    5
    Still searching...any help would be appreciated.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,525
    What shape is your basket in the skimmer? I bet a picture would be helpful.
    Kim
    NCSU's Avatar
    Sep 2015
    Goldsboro, NC
    5
    Quote Originally Posted by kimkats View Post
    Kim
    Rectangular http://www.inyopools.com/pool_parts_...s_skimmer.aspx
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    square vac plates seem to be non existent.
    an alternative that would easily work is this hayward debris canister...put it inline with the vacuum...problem solved.
    I got one before realizing i could have just bought a skimmer vac plate. Better yet this one catches much finer debris that
    would otherwise go to your filter. Glad I went with this instead.
    Amazon.com : Hayward W530 Large Capacity Leaf Canister with Mesh Bag Replacement for Hayward Pool and Spa Cleaners : Swimming Pool Water Pumps : Sports Outdoors
    Dolphin E10 Cleaning Robot.
    Jul 2012
    Tallahassee, FL
    30,525
    Well I never! Rock and hard place for you
    I am out of ideas.
    Kim
