Results 1 to 19 of 19
Thread: Now the opposite problem - too much chlorine....
    Jun 2014
    Houston, Texas
    479
    OMG. it's always something!
    Test the FC today and it was 7!
    I guess the cool weather and a 50 CYA is helping our chlorine situation???
    It's all over the map
    9/13 FC 2/cal 425/ta 100/CYA 60/pH 7.8
    9/15 2 FC/calc 350/ta 80/pH 7.5
    9/17 FC 8.5/pH 7.6-ish/CYA 50
    9/18 FC 5.5/ pH7.5, 6
    9/19 FC 5.0
    9/21 FC 2 - bleach added and SWG turned on <it had been not working but got it working>
    9/23 1/4 bottle of CYA and and FC 8.5 and CYA 55
    9/24 FC 8.5/Ph 7.7/CYA 55
    9/25 FC 4.5 and added 12 oz of acid/CALC 375/TA 100/CYA 50/pH 7.8
    9/26 FC 4.5
    9/28 FC 7/cya 50 pH is 7.8 again
    I know that chlorine eats acid. Hubby wants to wait and get the FC down before adding more acid.
    Thoughts???? I have a notebook. I don't test everything every day. I only have enough solution to test the CYA one more time. We have ordered more already. it hasn't arrived. Turned the SWG down to 20% - this is just crazy!
    19k SW IG
    Wet Edge pebble tech = new 5/16 (replaster)
    Hayward variable speed pump (new 6/17) /Shark for cleaning
    New - filled 10/18/14 - TFP 100 test kit
    38,548
    Re: Now the opposite problem - too much chlorine....
    Chlorine does not eat acid ... I have no idea what you mean by this.
    And 7ppm is really not that high.
    PH and FC adjustments are independent. Lower the pH now.
    wjr75's Avatar
    Jun 2013
    IL
    836
    I'm at around 45-50ppm of CYA and I usually target a FC of 7 sometimes 8 if I have a pool party planned but I have NSWG pool.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Mod Squad pooldv's Avatar
    DFW, TX
    24,517
    With CYA at 50 it is safe to swim with FC up to 20ppm. 7 is only 1ppm above target. Chlorine CYA Chart Yes, cooler temps and less sunlight are reducing your chlorine demand.
    More on pool chemistry here, Pool School - ABCs of Pool Water Chemistry
    domct203's Avatar
    Jun 2015
    CT
    3,600
    Why are you checking your CYA so often? Unless you have a good amount of water exchange it's not going to change much. I check mine once a month.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Jun 2014
    Houston, Texas
    479
    Quote Originally Posted by domct203 View Post
    Dom
    Bc I have had a chlorine problem. And I thought i understood that you had to have enough CYA to keep your chlorine from disappearing. We haven't been able to keep our CYA up.
    Quote Originally Posted by pooldv View Post
    We can't swim anymore. It's too cold. So I was right that the coolder weather has lessened the chlorine. Okay. We will lower the pH.
    and under pool school, it says that the CYA should be kept at 70 or 80. We have NEVER EVER been there. EVER. We haven't been able to get it up.
    19k SW IG
    domct203's Avatar
    Jun 2015
    CT
    3,600
    Quote Originally Posted by DMS2014 View Post
    I don't see any CYA additions in your notes you posted, except for once, a "1/4 bottle". Yet you tested 6 times?
    How much CYA have you added to your pool, and what form (liquid or powder)?
    CYA does not dissipate like chlorine does, nor does it (substantially) oxidize with normal FC levels. Either you have a bad batch of CYA, have not added enough, or there is testing error. Liquid CYA will take a day or two to completely disperse in the pool, powdered can take 4-7 days. If you test right after adding you are not going to see it.
    Dom
    Dom - TFP Guide
    Jun 2014
    Houston, Texas
    479
    Dom
    Look at the 13, 17, 23, 24 and 25. those are the days I tested the CYA
    19k SW IG
    domct203's Avatar
    Jun 2015
    CT
    3,600
    Yes, 6 tests but no CYA additions other than your mysterious "1/4 bottle". I thought that was already established?
    I don't see any CYA additions in your notes you posted, except for once, a "1/4 bottle". Yet you tested 6 times? .........
    Dom
    Dom - TFP Guide
    DFW, TX
    24,517
    1/4 bottle should be 1 lb which will raise cya by 6.3 ppm in 19k gallons.
    domct203's Avatar
    Jun 2015
    CT
    3,600
    That is assuming it was a 4lb container of granular CYA.
    It it could have been 1-3/4 lbs if a 7lb container, or 32oz if liquid.
    Trying to help figure out why their CYA is not rising, I asked what form and how much but OP has not yet answered.
    .......... How much CYA have you added to your pool, and what form (liquid or powder)?.......
    Dom
    Dom - TFP Guide
    Jun 2014
    Houston, Texas
    479
    Dom
    All I know is that it's liquid CYA. we don't have any more of it, but the husband says it's a gallon-size container.
    Dom
    Yeah, he added some - I remember but he didn't write it down. I remember him saying he was going to pour the rest in bc he thought what he added would have been enough and all that was left was the 1/4. Unfortunately I don't know exactly when. I have yelled at him for not writing things down!
    the FC was still 6 yesterday with the SWG set at 20%.
    19k SW IG
    domct203's Avatar
    Jun 2015
    CT
    3,600
    A full gallon of liquid CYA will raise the CYA level by about 19.5ppm in your 19000 gallon pool.
    It's good to see that you are now maintaining FC. How big is your SWG cell?
    Dom
    Dom - TFP Guide
    Jun 2014
    Houston, Texas
    479
    Okay, Dom, you have stumped me. I do not know the answer to that question of cell size. I am not even sure my husband knows. I will have to figure that out and get back to you but I am headed to a conference so it most likely won't be until Sunday when I Google the Hayward SWG thing.
    19k SW IG
    domct203's Avatar
    Jun 2015
    CT
    3,600
    No worries.
    How long are you running the pump & SWG? That's good output at 20%, unless it's running all day. The colder weather is also helping.
    If your not sure the size of the cell just post the manufacturer & model #, we can figure it out from there.
    BTW- Be sure to check out Pool Math. It's a very handy way to calculate "how much" of a needed chemical. Once you enter your pool's volume in the box up top, & set all your "now" and "target" values you hit the "calculate" button and pool math does the work! If I go there now and enter 19000 into the gallons box, set my CYA "now" to 40, and set my CYA "target" to 60, when I click the calculate button it tells me to add 131oz oz liquid stabilizer (just about 1-gallon).
    Dom
    Dom - TFP Guide
    Jun 2014
    Houston, Texas
    479
    yes, the cell is a 9.
    I have told my husband about the pool calculator! Again.
    19k SW IG
    Jan 2014
    Buckeye AZ
    807
    so your CYA is in the 50 to 60 range. That could be the result of either pool water or R-013 measurement being slightly less or more than last time, or that could be difference in ambient lighting. Just say 60, and get your FC to 8 each night at sundown. Test for pH once a week and add some acid if needed. Check you CYA once a month. If it went down, it just means you used a little too much chlorine in the mean time. It's never going to magically get higher, so you aren't at risk for algae, just a few lost dollars on a few ounces of bleach each night.
    If you don't have any actual issues with algae or cloudy water, you seem to be over-steering. Relax your grip on the wheel!
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    Jan 2014
    Buckeye AZ
    807
    oh ok, the SWG is working? Your FC will vary throughout the day, higher when the pump has been running and distributing the chlorine, lower if it's been sitting stagnant in the sun all day, etc. I would measure whenever the level is probably the lowest: back half of the day when the sun is out but the pump hasn't been running.
    For the CYA, just assume 60. Next month, if it's still 45-55, you can add enough to bring it up. Unless your cell is taxed, you can work your way up. And yes, try a different brand of stabilizer. That's been a thing this year, CYA not coming up as expected.
    Jun 2014
    Houston, Texas
    479
    I'm a type A personality, Buckeye! LOL. No, actually, as a first time pool owner, it's been rather challenging -- especially with the crazy weather we've had this year. We actually dumped water from the pool 3 times this year - had algae twice. it's been a ride!
    19k SW IG
