Thread: Leaking Hydrostatic valve?
    Jun 2012
    Northest Florida
    23
    Thinking my hydrostatic valve is leaking ..... can it be changed with water in the pool?
    24K Marcite 1.5 Pentair Pump 380 Polaris
    Jun 2015
    Wildomar, California
    423
    Re: Leaking Hydrostatic valve?
    The valve might not be bad, but could be stuck by some dirt or debris. Other than a pool tech who does scuba repair, draining it down is all I know. Hopefully, another TFP expert has another way. Oh, yeah, why do you think your HV is leaking?
    Jun 2012
    Northest Florida
    23
    long story but basically plugged off the two skimmers and let main drain serve as only return to the pump ... when I plugged the skimmers the water dropped to the bottom of the tile and everything has been good for about 6-8 weeks ....but now suddenly loosing water again. now that fall is here getting more leaves in the pool and the drain will get covered by leaves and I figure the suction from the pump has pulled the valve open and like you stated prob trash is keeping it open .....I'm thinking about just plugging the valve until we decide what we are going to do .... meaning rehab ... As long as I keep the pool full there should be no issue with capping the HV?
