I had to entirely drain my pool because I had to get it resurfaced. My pool has a fiberglass gelcoat on it and it is about 38,000 gallons. I am using 10% liquid chlorine to close it. I have a 50lb bag of calcium chloride flakes and it is 77.7%.
How much do I need to add if we are assuming the level is at 0% right now? I will use my taylor kit to get an exact amount after the pool is finished filling up. I have used the pool match calculator, but it does not say what percentage the calcium chloride is in the calculator. Does the CH calculator in the pool match section assume 100% calcium chloride?
Josh
Josh
