Thread: Think I added too much de...what to do?
    Oct 2013
    Baton Rouge, LA
    86
    Hi guys,
    Back washed my new 6020 Hayward de filter setup. When adding de, I added the 7.5lbs it said on the filter. After reading post on here I noticed you guys say to add 80% after backwashing. Filter appears to be running fine, but should I backwash it out again and start over? What do you guys recommend?
    Thanks
    30,000 gallon In-Ground vinyl, small fountain, Polaris 9300 robotic cleaner
    JoyfulNoise's Avatar
    May 2015
    13,201
    As long as you're getting adequate flow from your returns you should be fine.
    What is you current clean pressure reading as compared to previous clean pressure readings?
    You only add the full manufacturers amount of DE when you do a complete tear down and cleaning of the filter. When you back wash, add about half to 3/4 the amount.
    Matt
    Oct 2013
    Baton Rouge, LA
    86
    Re: Think I added too much de...what to do?
    My normal pressure is 10psi after backwash and is currently 12psi...
    Jun 2011
    Long Beach, CA
    2,784
    If the return flow is still strong you should be able to get away with it for a little while. When the pressure hits 13 psi I would do a complete tear down of the filter to make sure it had the proper amount of DE. Most filters don't get a full cleaning like they should, at least once a year.
    I add 2/3rds of the amount of DE when I backwash mine.
