Results 1 to 17 of 17
Thread: Is this Algae?
    Aug 2015
    Central, NJ
    142
    Is this Algae?
    Hi,
    So I'm a month into my new pool and I have some brown looking stuff at the bottom all of a sudden. I couldn't brush it off, so I'm thinking it's algae. Here's a picture:
    Am I right? I tested my pH and Cl this morning and the Cl was low (probably around 0.9) so I added bleach immediately (trying to get it over a 2). The pH was around 7.7, so I added muriatic acid (trying to get it down to 7.4). FYI - my SWG hasn't been started yet.
    Any advise on what I should do?
    Thanks!
    In-ground 47'x25' free-form gunite pool w/ spa w/ waterfall. 35,380 gallons. 3' to 8' deep. 96 sq ft 6" deep sun shelf. SunStone Select Quartz Finish (Graphite). 2 Hayward skimmers. Jandy DEV60 DE Filter + Pro Series Plus 2HP Pump. Polaris PB4-60 Pressure Cleaner Booster Pump. Raypack P-R406A Heater. EasyTouch 8. IntelliChem w/ Acid Tank. IntelliChlor IC60. Techo-Bloc bullnose coping + Blu 60 mm paver patio. Merlin SmartMesh cover. TF-100.
    Aug 2015
    Central, NJ
    142
    Re: Is this Algae?
    By the way, not sure if this matters...I'm in NJ and the weather has been getting colder (around 70...but some days are still hitting 80). I haven't had my heater on continuously. I was planning to close the pool mid-October, as I'd be using the heater whenever we want to swim, but not running it continuously. Can this contribute to algae growth?
    I was thinking to keep the pool open until then, to that I can keep treating the water for a while (since it's a new pool and I was thinking that the plaster is still curing somewhat.
    38,251
    Re: Is this Algae?
    If it won't brush off, I would doubt algae. Looks like rust stains to me. Put a vitamin C tablet on it for a minute or so and see if it lightens or disappears.
    Any girls leave a hair tie with a metal band on it in the pool?
    What is your CYA? That is what determines you required FC level ... 2 might be too low. See the FC/CYA Chart for the non-SWG levels (since you are not running it yet).
    Aug 2015
    Central, NJ
    142
    Re: Is this Algae?
    My CYA is around 28 now. It had been at 20 and I knew that I had to increase it, so I put a bunch in a few days ago. I know that I have to wait longer for it all to register, so I'm hoping I hit 40 in a few days from now. Meanwhile, my FC is definitely low so I'll increase that.
    I have to get a vitamin C tablet - don't have that right now. I'm not sure how we'll I'll be able to rub it though, as the staining is in a deeper part of the pool. Any tips on how to do this in a deeper area?
    Aug 2015
    Central, NJ
    142
    Re: Is this Algae?
    I got some vitamin C tablets, and I was able to swim down there and rub one of the spots. It definitely got lighter, so the stains are from metal.
    Aug 2015
    Central, NJ
    142
    Re: Is this Algae?
    So the vitamin C working means I have an iron problem, right? Does anyone have advice as to what's the best way to fix this issue if I just few a few spots?
    I see how to do an abscorbic acid treatment, but it's just a few spots, so I'd rather avoid having to do an entire pool treatment.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: Is this Algae?
    Crush the vitamin c and place in a sock. Either rub it on the spots or use your pole to hold it there for a few minutes. Move it around a little. The spots should disappear like magic. Since it's only a few, and appear to be from 'something' I would not worry about sequestering at this point.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    38,251
    Re: Is this Algae?
    Just set the tablet on the stain and let it dissolve.
    To have spots like that likely means that something metallic was sitting on the bottom, not a problem in the bulk of the water.
    Aug 2015
    Central, NJ
    142
    Re: Is this Algae?
    I got rid of all the spots by rubbing them all with vitamin c tablets and letting the sock filled with tablets sit on some of them for a while. Should I do anything to prevent a recurrence? Or just wait and see?
    38,251
    Re: Is this Algae?
    Wait and see.
    Aug 2015
    Plano, TX
    217
    Re: Is this Algae?
    I tried the vitamin C trick with a few spots of staining I have when someone decided to throw a mini hacksaw blade over my fence and into the pool during the winter and I couldn't get it out. Of course the robot kicked it around a bit so there are several spots it sat in. So I know for a fact that these are metal stains, but I can't get them to lighten up at all.
    Curtis- 20k gallon IG gunnite/plaster with hot tub/waterfall and "grotto"
    All Jandy equipment: 60sqft DE filter - 399k btu natural gas heater - Stealth pumps - iAquaLink RS8.
    Polaris 9400 on patrol.
    TF-100 in da house/TFP method in effect: FC=4-6, pH=7.5, TA=80, CH=250, CYA=50, Borate=50, CSI=-0.21
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: Is this Algae?
    Crushed vitamin C in a sock? Didn't work? WOW! I would have bet money that it would have. Try holding a puck on it for a few mins. Really, those are the two best ways to tell what you got.
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,245
    Re: Is this Algae?
    Joe:
    Do you have any trees that drop anything into the pool? During the summer (now of course nuts are falling from the sky), I had small brown things that dropped from the tree and if left on the steps (white steps) more than a few days, a stain would appear. Considering you have concrete, is it possible something from a nearby tree is dropping something in the pool. Try the methods explained in the previous post to see if you can remove the stain. They drop and bounce almost 25' out. Pool cover is on.
    The stains looked very similar to yours, like there was a streak. Chances are that the object moved slightly causing the streaking.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Aug 2015
    Central, NJ
    142
    Re: Is this Algae?
    Catanzaro: Yes, I have a few trees nearby that are dropping stuff in the pool. Thanks for pointing that out.
    So it's been 4 days and I'm seeing a few new spots. The original ones are still gone. The new spots are in totally different area of the pool.
    Am I correct in thinking that I just need to add more sequestrant to the pool to solve this? (to keep the iron suspended) If yes, would the Blue Stuff be a good option?
    Also - am I making matters worse by keeping the pool open as it's getting colder and leaves and dirt are falling in daily? I'm cleaning it as much as possible, but wasn't planning on closing until 10/15. I was trying to keep the pool open and keep treating the water, since the pool has only been running for 5 weeks or so. I wasn't sure if closing it so soon after first starting it up would lead to issues. (for example, if the plaster is still curing and still needs the water treated, rather than covering it and waiting until spring)
    30,403
    Re: Is this Algae?
    I like the idea of keeping the pool open as long as possible. With NO precise scientific data to back me up, it is simply my opinion that the more time you give your pool to "settle down", the happier you will be when you open in the Spring.
    Catanzaro's Avatar
    Jul 2014
    2,245
    Re: Is this Algae?
    Simple thought! Cover the pool up after removing all the stains as you did previously. Keep running pool as normal for a few hours. Wait a couple of days (last test was 4 days), to see if any more spots or stains show up with the pool covered. If they do, then you can eliminate any outside elements causing this issue. If they do not, then something from the outside is doing this. I do not know what type of cover you have, but if a safety cover, then you can anchor every other one, or only ones to secure the cover. Simple process of elimination.
    Jul 2013
    Long Island, NY
    141
    Re: Is this Algae?
    They look like acorn stains to me...I put a puck on them for 20 min and they disappear.
    20x40 in-ground Bella Blue Pebble Fina pool w/diving board, 1 HP Hayward Superpump, Raypak RP2100 335k BTU NG mV heater, Pentair Quad DE 60 filter, Pentair 261173 multi-port valve, Stenner 45MPHP10 pump w/15 gal tank, Intermatic ET1125CR dual electronic timer, 1.5" lines, two skimmers w/socks, Poolskim, vacuum line, ColorQ Pro 7 kit, TF-100 kit, speedstir, 2 froglogs, Dolphin Discovery Robot. Wine is the answer, what was the question?
