Results 1 to 12 of 12
Thread: What is the best SWG brand ?
    Sep 2015
    Bradenton
    71
    Hi Guys,
    In your experience and knowledge, what is the best quality brand for an oversize SWG ?
    After reading some reviews on Amazon, I am concerned that some brands have electric board problems.
    Any suggestions are greatly appreciated!
    -JJ
    8,000 Gallon Pool in SW Florida
    30,426
    Re: What is the best SWG brand ?
    Unfortunately, it is the same brand as the best brand of car.
    If one was clearly better than others, it would quickly dominate.
    38,370
    The Hayward's are very common and a nice mid-range unit. Since they are so widely used, the typical issues are well know and generally very easy to fix.
    But as Dave said, other major brands are just as likely to be good too.
    Some have some drawbacks. Like the Pentair can only be adjusted in 20% increments without their automation and since the electronics are on the cells, the replacement cells cost more.
    Sep 2015
    Bradenton
    71
    Thanks guys,
    I have been hesitant with the Hayward because of all the motherboard electrical issues in the Amazon reviews. Perhaps I'm missing something and this can be easily avoided ?
    Do you suggest the 25k or 40k option to oversize for an 8,000 Gallon pool?
    Thanks guys for the help!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    25k will be fine. We recommend 1.5-3 times larger.
    38,370
    Maybe not avoidable (although I have never had the issue with the board), but often repairable for < $5
    Sep 2015
    Bradenton
    71
    Thank you, good to know.
    Which unit do you have and what output % do you use?
    38,370
    Every pool is different. The output setting will depend on your pump run time and sun exposure and debris exposure and CYA level, etc.
    I have the 40k on my 18k pool.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    I have been using the Hayward (Goldline) AquaRite T-15 for 10 years. I had the common problem with the input resistor last year. A $2.50 part and 15 min with a soldering iron, and it's back in service. The best value will always be obtained by purchasing the higher output T-15 cell, regardless of how small your pool may be. It will last much longer and is capable of putting out much more chlorine and at a higher rate. The control unit will let you adjust the output in one percent increments from 100% to 1%. A T-15 cell lasted 7+ years in my 19k pool. In your size pool it should be a decade or more before you have to even think about a new cell.
    chiefwej
    Sep 2015
    Bradenton
    71
    Quote Originally Posted by chiefwej View Post
    Thank you, that is very helpful.
    I was thinking that as long as it is compatible and there is no downside, it would make economical sense to buy the largest cell.
    What output % do you use in maintaining chlorine level in your pool?
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Currently in my very sunny pool I'm running the SWG for 7 hours a day at about 40%.
    chiefwej
    Aug 2015
    Maine
    45
    The engineer in me loves complicated stuff. The controls engineer in me loves simple stuff. I went with the PureChlor system as American SPS seems to come highly rated, and they are fairly simple. Love it so far....
