Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: Problem blowing out pool lines
    I am using a 3 gallon compressor and psi at 20. One of the skimmer lines air blew out and we closed it up, but the other skimmer and the 2 return jets nothing is coming out of them. Anyone know what I could be doing wrong?
    25k Gallon Gunite Inground Pool
    Pentair FNS PLUS DE filter
    Pentair WhisperFlo WF-24 (seems like single speed)
    Bel Air, MD 21015
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,256
    Re: Problem blowing out pool lines
    You probably do not have enough volume to move the water. I use the Cyclone and the first 2 lines on either side went first, but after that it was one line at a time. The only thing I can suggest is too close off and isolate everything and blow out the lines one at a time. You may have problems with the main drain on this one.
    If you have 2 return jets and 2 skimmers, close off both jets and one skimmer. Now work on the first skimmer and after this is plugged off, remove the other skimmer quickly and work on this one. Repeat the process. Also, from where are you blowing out the lines? Do you have the filter on recirculate? Close off the multi-port valve when working on the skimmers, then open to recirculate.
    Maybe it is best to plug the suction line (Skimmers & Main Drain)in the pump basket and work on the returns first, then move on to the skimmers and main drain.
    Please post some pictures of equipment, etc. The more pictures, the easier to follow. Thank you.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    I think the problem is I took off my DE Filter cover while cleaning out the Grids? I will put that back on and try again later this afternoon. Do you think that would be part of the problem?
    Bel Air, MD 21015
    If the multiport valve is on filter, air will be lost if the filter is open. Try putting the multiport on recirculate.
    Support the site
    Catanzaro's Avatar
    Jul 2014
    2,256
    Quote Originally Posted by JamesW View Post
    Yes, please do this as JamesW mentions. I had mentioned this in my reply. You are bypassing the filter at this point by placing my multi-port on recirculate.
    ok I put the multiport valve to recircurlate, and now both my skimmer lines are working well and I closed them up. But now nothing is coming out of my return jets? Somethings seems off.
    Bel Air, MD 21015
    ok I almost got it to work, everything is blown out except for my main drain. What do I need to put the pool drain too and the pool drain return too to blow out the main drain?
    Bel Air, MD 21015
    If the other lines are blocked, the main drain should go if the valve is open. The main drain takes longer than the others due to the depth. Once the main drain goes, close the valve. Be careful not to over pressure anything.
    Support the site
    I have 2 separate valves for main drain and main drain return. I am assuming main drain needs to be open while blowing out the lines, then close it once bubbles come out. But my question is what should the main drain RETURN be set to. I had it off the whole time.
    Bel Air, MD 21015
    The valve has to be open to allow air to go down.
    Support the site
    It still doesn't seem to work. Its weird because all my other lines blew out well. This is driving me nuts today!
    Bel Air, MD 21015
    Compressors do not move a lot of cubic feet per minute. You might not be waiting long enough or you might have air leaking out somewhere.
    Support the site
    How long should I waiting roughly. I waited like 2 minutes..
    Bel Air, MD 21015
    It depends on the cfm (cubic feet per minute) delivered by the compressor and how much volume needs to be cleared. The volume of the pipe is determined by length and diameter. Try waiting a few more minutes.
    Support the site
    Catanzaro's Avatar
    Jul 2014
    2,256
    Quote Originally Posted by precator View Post
    As JamesW mentions above. There may not be enough volume.
    Please make sure main drain valve is open. Then, it is suggested that you have everything closed off, plugged, valve turned so only air is heading down to the main drain. If you can post pictures of the plumbing that would be great. You only want air moving towards the main drain. You might have an air leak coming out, but my guess is the 3 gallon tank now sending out a burst of air is not enough volume to move water and/or create a lot of bubbles at the main drain. When you send air down to the main drain, how quickly does that tank dump and start filling up again?
    Question on removing water and pushing air through system
    Take a look @ Post # 8. Maybe when the tank dumps, you could allow it to fill up and then once you open up the tank open the valve again. Or as Pool Tool states that he starts with fairly low pressure until most of the water is removed and then he increases pressure to get every bit out. He does not mention main drain, but you can give this a try.
    Notes that I had acquired prior to Cyclone Purchase
    This is all the information that I gathered over the months.
    • Blowing out an 8 foot deep Main Drain line only takes about 3.5 - 4 psi.
    • The motor has to be large enough to keep around 15-20 psi in the tank so you can keep a constant 8-10 psi going into the lines.
    • Do not over pressurize the lines. 5 to 10 psi is sufficient.
    2 skimmers at 100 feet of 2 inch PVC..............4 cubic feet
    1 main drain at 100 feet of 2 inch PVC.............2 cubic feet
    1 Polaris line at 100 feet of 2 inch PVC............2 cubic feet
    1 vacuum line at 100 feet of 2 inch PVC..........2 cubic feet
    2 Return lines at 100 feet of 2 inch PVC..........4 cubic feet
    3 foot diameter sand filter...........................14 cubic feet.
    Miscellaneous.............................................2 cubic feet.
    ________________________________________________
    Total......................................................3 0 cubic feet
    Word of caution when blowing lines with a compressor. They don't usually blow enough volume to displace all the water. It may only form a tunnel in the pipe.. It can blow a hole in flex pipe. Line blowing is best done with a high volume of low pressure air. Compressors generate low volumes of high pressure.
    Please make sure that you have your compressor on low pressure to create more volume. Maybe check the specifications on your air compressor to determine if this is even possible.
    Last edited by Catanzaro; 09-27-2015 at 06:21 PM. Reason: Notes that I had acquired prior to Cyclone Purchase
    IMG_1799.JPG So I have both a pool drain valvle and a pool drain return valve. I am assuming pool drain should be closed and pool drain return should be opened? if bubbles come out then close the pool drain return valvle? also, I had the psi at like 20 - 30 psi, do you think I damaged the pipes? I didnt realize psi should be so low.
    Bel Air, MD 21015
    Catanzaro's Avatar
    Jul 2014
    2,256
    Can you please send an enlarged picture. This picture is only of the "Jandy Valves". The whole set up would be nice. Something like these pictures below. Then we can go from there. Do not go over 20 PSI on the setting. Everything has to be closed besides the main drain. Then after bubbling, you can close the valve to create the "air lock".
    These pictures show the whole setup & the top view as well.
    ok but I guess I am confused, I would assume the valve labeled "main drain RETURN" would be open and not the valve labeled "Main Drain". Is this correct or am I wrong? I will try to take pics later tonight.
    Bel Air, MD 21015
    Catanzaro's Avatar
    Jul 2014
    2,256
    Please post some pictures and we can go from there. I do not know how they were labeled. You would know your system better than we do. The valves should have pins in them so you accidentally do not shut down both the main drains and the skimmers at the same time. You could easily remove them, but not recommended.
    How many returns do you have? I have 2 sets. One valve controls both. They are either all open, or only one can be closed at the same time. I have one valve that is completely closed off so it does not move to protect the returns from accidentally being moved and also have a return for the waterfall that was never built and is there for the future.
    As you can see in my pictures, I have 2 valves for the suction side (going into the pump) for the Main Drain and Skimmers. The pipe coming out of the filter is for the returns. Sometimes in older style pools, the main drain and skimmers are all hooked up together. I am assuming your set up is not.
  20. Back To Top    #20
    IMG_1802.jpg attached is my setup. Please advise
    Bel Air, MD 21015
