Thread: Taylor refill reagents question
    Jul 2015
    South County, Rhode Island
    36
    Good Day, everyone. I have been using the TFP method now for a month with my new spa and everything is magnificent, many thanks. I will be in need of PH drops and was wondering if they are pretty much universal? I can obtain them locally at a reputable hardware or spa retailer. If this is a correct assumption, do I have to be sure they are the "5 drops at a time" type? I seem to remember seeing/using some that were 3 drops per test decades ago. Your input is greatly appreciated.
    2015 Bullfrog 131 180 gal Spa Indoor, TFP bromine fed, Taylor K-2106
    2012 2500 gal. Round vinyl AG Pool, Hayward Easy Clear Filter System, chlorine
    1994 Rubbermaid 175 gal horse tub, still looking for advice on algae problem.
    Jun 2014
    15,103
    Re: Taylor refill reagents question
    A couple things to keep in mind when shopping for pH reagents. There are two kinds out there - R-0014 and R-0004. For your kit, you want the R-0004, not the R-0014. Your local pool store should have those replacement reagents for you in the Taylor brand. It's always possible that some "other" brands have a slightly different concentration.
    Hope this helps.
    Last edited by Texas Splash; 09-27-2015 at 07:27 AM. Reason: Made correction to the reagent type
    Jun 2014
    15,103
    Lyd, correction to my first reply above. The Taylor K-2106 you use contains the R-0004 Taylor reagent. It is not universal and, generally, is the only replacement you should use for your K-2106. I overlooked that in my first reply to you. Reagent R-0014 is not the correct one. Sorry for any confusion.
    JoyfulNoise's Avatar
    May 2015
    13,201
    This is the component list webpage for the Taylor K-2106 Kit. The phenol red pH drops are R-0004. You MUST use R-0004 drop with the 9058 comparator block.
    If you need refills, you can easily order them online. I would not mix and match other vendors reagents with the Taylor comparator block. They are not same chemistry formulations. Taylor specifically formulates their phenol red drops to reduce FC and eliminate interferences. PoolMaster phenol red drops require the use of a dechlorinator prior to use. I'm not sure what HTH does. Concentration of phenol red affects the color intensity and could give a false read in the wrong comparator block.
    Matt
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    TFTestkits.net also sells it. R-0004 refill
