Thread: Clearwater generator has issues
    Sep 2015
    San Juan Capistrano
    1
    I have a new VS pump which means I no longer need a time clock to determine when my motor starts up. However, I also have a Clearwater chlorine generator that needs a time clock. The problem is I ran my Clearwater after the pump turned off now I am able to super chlorinate only but nothing less then that. Have I damaged the mother board on the system?
    I have a newly rebuilt 20k gal pebble(modified) in ground pool, with an attached spa, in southern California. I have a Clearwater chlorination system and I am anal about the condition of the water.
    Sep 2013
    Charleston, SC
    537
    Re: Clearwater generator has issues
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
    Jun 2011
    Long Beach, CA
    2,784
    There is not much info on that system as it seems it has been discontinued.
    Have you looked inside the cell and on the pc boards for obvious signs of damage?
    Are there any errors that get displayed when it is not working?
    The flow sensor should have detected no flow and cut power off to the cell, but that isn't 100% guaranteed. After this make sure you sync it with the pump some way.
