Thread: Help wiring an internal switch on a new pump
    Jun 2015
    Patchogue NY
    8
    Hello - this is my first post to this site. I replaced my single speed one and a half horsepower Pentair pump this week. The new pump did not have a power cord or a switch like the original pump had. I was able to wire the power cord with no problem. I could not figure the wiring to put a switch on the body of the pump - diagrams from pump housings are attached (I hope). Any help from the forum members would be appreciated! I am not in a rush - I will add the switch during the winter after the pool is closed.
    Chris
    10000 gallon semi-inground vinyl 2009; 1 hp single speed Pentair Dynamo, Pentair Star St-80 DE filter, sta-rite 200Kbtu LP heater
    Jun 2012
    western NY
    1,562
    Re: Help wiring an internal switch on a new pump
    We will need to kow what the supply voltage is to the pump. Since you said the old pump had a cord/plug assembly on it, I will hazard a guess that it is 120 volts. If so, use the schematic for the low volts. Hook the black wire to terminal 1 and the white wire to terminal 6. If you want to put a toggle switch in to shut the pump off/on then install it on the black line.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Jun 2015
    Patchogue NY
    8
    Thanks for the reply. The pump is running on the 115 v power. The pump is running now with no problems. I couldn't figure out why the toggle switch on the old pump interrupted power to the blue line (which was wired into the coil instead of the board). I will check the rating on the switch from the old pump and interrupt the hot black line with the old switch.
    Chris
