Thread: Pool light sludge...grease or algae?
    Jun 2014
    Casselberry, FL
    11
    Hey all,
    Total noob question, but I'm currently replacing my pool light and when I separate the lens from the casing, I quickly realized that the casing was full of a greenish/brown sludge. It looks like grease to me, but I can't for the life of me figure out why anyone would put a large amount of grease inside a pool light enclosure. My only other thought is that it might be some form of algae, but I've never seen it so concentrated like this. I've attached some pictures so you can see what I'm dealing with. Thoughts?
    18-20k gallon in ground pool w/gunite surface
    Leslie's Crystal Clear II DE filter - DE-LE-42054 - 96gpm
    Hayward Super Pump with AO Smith UST1102 1.0HP motor
    Non-SWG
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    Re: Pool light sludge...grease or algae?
    Yuck!!
    Can you wipe a bit on to white paper and perhaps then can see if its greenish or black?
    I'd assume it was algae and clean that sucker out gooooood with bleach.
    And monitor your pool chems closely for a little while in case you dropped some into the water.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    I dont know why anyone would put grease in there either. But - Pool light niches are famous for harboring algae.
    That looks excessive from what Ive seen, but it could be. Grab a blob and put it in a box and let it dry out. If its algae, it will dry up like any plant will.
    Divin Dave,
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    When I pulled mine out last year it was similar and diff algae. Scrub it down good with bleach before installing.
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
