Thread: Air leaking out of return plugs
    When closing this year, I have air leaking out of both of the return plugs after blowing out the lines. I tried a new plug, but still have the issue. I use the screw in plugs, and tightened hand tight and when it did not seal I tightened it slowly all the way, but both continued to leak. Do I have to replace the return faceplate? The faceplate appears to be a Hayward with four screws in it. Its a vinyl pool. Thanks for any help.
    Chris
    19,000 vinyl pool, solar heat, .75 hp tristar, 48 sq ft de filter
    May 2013
    Long Island NY
    419
    Re: Air leaking out of return plugs
    Quote Originally Posted by ChrisL View Post
    Chris
    Read the post about 12 down from your post. Winter plugs.
    19,000 gal - Vinyl IG - Sand filter -1.5hp. - Taylor k 2006 - Loop Loc cover
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,256
    Quote Originally Posted by samt View Post
    Winter Plugs (Any experience with the threaded ones))
    I believe Sam is referring to this post, but it was moved up. I started the post and had the same issue with the screw in plugs. Please read post. Use the rubber plugs, they work best.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
