Thread: Oops! 😁 Water temp!!
    MermaidMama's Avatar
    Aug 2013
    Pennsylvania
    158
    Took out ladder, vacuumed, tested CYA, gonna run pump 24 hours, loaded chlorine up to shock level. Then just came on and double checked what I needed to do, and saw the water temp needs to be below 60!! Ugh. The pool is at 70.
    We were going to drain tomorrow, put the cover on and put the pump filter away etc.
    Not sure what to do now??
    MermaidMama
    18' Round x 52" Doughboy AGP ~ TF-100 Test Kit
    Powerline XP Pump 1.5 HP ~ AquaView 20" Sand Filter ~
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,095
    Re: Oops! 😁 Water temp!!
    In the end, it's not the end of the world. Just get some polyquat 60 and put it in. Then close as planned. Worse that can happen is you might not be clear in the spring. We can take of that if it happens.
    Others might have a different plan, but that's what I would do if it was me.
    Bob - Soon to be INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,552
    At least the ladder is out! Recheck your chlorine SLAM level when you actually do drain down and close.
    Aug 2014
    Northern IL
    4,615
    Personally, I would just wait to close. What did you decide to do?
