Results 1 to 16 of 16
Thread: New Owner
    Sep 2015
    FL
    24
    New Owner
    I had a pool growing up and am somewhat familiar with the level of effort required once it is in operation.
    I did have a cheap above ground pool at my last place but got a saltwater system and just put in water and salt and called it good. It ran great for 3 years with very minimal effort other than draining it, refilling it, and adding more salt at the beginning of the season.
    I Just purchased a home that has a pool. It was a foreclosure that sat vacant for approximately 2 years so to say that the pool needs attention is an understatement. Here is what it looked like when I moved in.
    I have since gotten the wood removed and am in the process of getting all the plastic off the top. I get the large pieces then turn on the pump and let the skimmer pull the small pieces. The next day there are more large pieces that have floated up from the bottom. I'd like to just drain it, scrub it, and refill it but am concerned about it popping out of the ground when it is empty. I have read a couple threads here on the subject and plan to dig a couple holes around it to check the water table. I do have a pond about 50 yards from the pool that is holding water so I think I may have a valid concern.
    As I look at the pump and filter setup there is only one input into the pump. The pool I grew up with had two inputs, both with valves, so you could choose to pull from the skimmer, the drain at the deep end, or both. Seeing only one input I do not have that choice with this one. Since I cannot see the bottom of the deep end I am assuming that I have a pickup there, but maybe not.
    As an aside at least someone is enjoying it now This is a banded water snake and was not harmed. He got in and apparently could not get out on his own so I put a 4x4 in, resting it on the edge of the pool and a step, making a ramp and haven't seen him it 2 days.
    Jun 2014
    15,059
    Re: New Owner
    Hey Rock, welcome to TFP! You and your snake. You are the proud owner of a mess, but we can help you turn it into a jewel. Take a few moments to review our Pooh School Page and especially the SLAM page (links below) since you will need those soon. Hopefully you have a TF-100 or Taylor K-2006 to test the water, if not, the TF-100 link is below in my sig as well. That should be priority #1. Welcome to TFP. Have a great weekend.
    30,414
    Re: New Owner
    Welcome to the forum.
    Quite a project! Very good news that your pump is running. Have you looked inside or tried to backwash your filter yet?
    Once your equipment is up and operating, You may want to consider some cosmetic repairs, The tile work looks like it was DIY and will need some things done to get it in decent shape.
    You'll find a lotr of folks here willing to help and many with the experience of DIY themselves. We look forward to your progress.
    Aug 2014
    Houston tx
    2,524
    Re: New Owner
    And we love pics!!
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,448
    Re: New Owner
    OH goodie!!!!!! A swamp to turn into a jewel!!!!!!!! What fun! I can't wait!
    HI! We LOVE pools like this! AND you are in Florida!
    So lets get started!
    First step -find an post to TFP-done!
    Second step get the TF-100 XL option---------have you ordered it yet?
    Third step - finding your best source for bleach/chlorine--------some people find it at Walmart Greater Value plain bleach. Others find it at Sams or Costco. Some find it at their local pool store. I find it at my Ace Hardware up the road.
    -Make sure to check date codes as old bleach is NOT good.
    -Check how strong it is-Walmart=8.25% Pool stores=11%. If there is not % listed do NOT buy it as it is almost always 3% or less
    Let us know how we can help you clear that pool.
    Kim
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: New Owner
    This will be a task but easily do-able.
    If there is indeed a main drain, it will be plubmed into one of the ports on the bottom of the skimmer. If you dont have one, no worries. Lot's of pools don't have them.
    Here are some references that will help you out
    Pool School - SLAM - Shock Level And Maintain
    http://www.troublefreepool.com/calc.html
    Pool School - Chlorine / CYA Chart
    TFTestkits.net
    Divin Dave,
    Sep 2015
    FL
    24
    Re: New Owner
    Quote Originally Posted by kimkats View Post
    I'm only 2 hours from you. I'm off all next week. When can you be here
    Pool: In-ground, Kidney Shaped, Unknown Size, Sand Filter.
    Sep 2015
    FL
    24
    Re: New Owner
    The pup is running because it is brand new It was after all a foreclosure. None of the rooms had any light fixtures and all the flooring needed to be replaced.
    I have not taken a look inside. What is involved in doing that? It looks like to look inside I have to disconnect the three pipes. If I do that is there a special PVC fitting I can put in that would allow me to do that again without having to cut and then patch the PVC? It is already looking kind of like a patch work quilt now
    Jul 2012
    Tallahassee, FL
    30,448
    Re: New Owner
    Rock I wish I could come help you figure out your equipment and start your SLAM BUT I am a teacher. A Kindergarten teacher at that. Do you have ANY idea how hard it is to find someone dumb or crazy enough to sub for us????????? LOL
    Okay on to you filter. Take some pics and we can/will walk you through it. Here is a link that show unions like you can put on the lines so you can work on your stuff.
    Google
    Kim
    Sep 2015
    FL
    24
    Re: New Owner
    Got a quote from a local pool company to come take care of it. With the water table as high as it is (about 18" below the concrete) I figure it is best to just let them pump it out and take care of it. My main concern with doing it myself is floating the pool so I assume that they know what they are doing to keep that from happening. What questions do I need to ask / what phrase do I look for on a contract to make sure that they are responsible if the worst happens? I mentioned this several times to the guy that came out to look at it and he implied it would not be an issue. They were used to working in the area with the high water tables.
    clambert1273's Avatar
    Jun 2013
    Cerritos, CA
    576
    Re: New Owner
    I am just here to watch
    Christina
    ~14,000gal 14x30 IG vinyl, Hayward DE4820 filter (everything else is too old to read lol), TF100 Test Kit, TFPC method
    POOL SCHOOL, ABC'S of WATER CHEMISTRY, POOL MATH, SUPPORT TFP!!, TEST KIT!
    Sep 2015
    FL
    24
    Re: New Owner
    They never called so I guess they are out. After looking at it further I think it will have to be re-plastered. I scrubbed off some of the gunk in several places and it is VERY rough. I can't see being able to be in there for mor than 5 minutes before your feet are raw.
    The guy that came by gave a ballpark estimate of $16K to re-plaster. Guess this will have to wait till next year unless I can figure out how to do it myself.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Re: New Owner
    It is likely calcium scale that is making your pool rough. Since you are going to have to wait to replaster anyway you can try to make it better in the meantime. In Poolmath there is a CSI scale number that is calculated after you enter your test results. Keep this number -0.3 to -0.5 and brush the rough spots as often as you can stand to. Over a couple of months this will likely help to reduce the scale. CSI is best adjusted by tweaking PH first and TA as needed.
    More here to get you started
    Pool School - Calcium Scaling
    Langelier and Calcite Saturation Indices (LSI and CSI)
    Sep 2015
    FL
    24
    Re: New Owner
    Got another quote today for $8400 and if I signed a contract this week for completion before Labor day he would give me 10% off of that. That is a lot more doable. Got another company supposed to come by Friday to give me a quote. Since I am in the panhandle of Florida we still have a couple of months of use left this year.
    I wonder if prices on these kinds of things go down in the off season.
    Next question is what am I looking at monthly to keep it going in chemicals etc?
    At my old house I had a cheap Wal-Mart above ground with saltwater and it was simple. I just filled it up, added salt, and ran the pump about 2 hours a day. Never had to do anything else to it and the water stayed crystal clear. Got 4 years of use out of that one so I figure we more than got our $600 out of it.
    Sep 2015
    FL
    24
    Re: New Owner
    Finally booked the company to come out and resurface next month. I'll keep this thread updated with pics as they complete the process.
    GaryT58's Avatar
    Jul 2016
    Monroe, GA
    570
    Re: New Owner
    Great. Looking forward to seeing pics.
    38'x16' Fiberglass pool - 3.5' - 8' deep - 19,000 gallons. AutoPilot Total Control SWG (RC-52 cell), Pentair SuperFlo VS, Pentair SD70 Sand Filter, Coverstar Automatic Cover, 10' board, PAL Treo lighting, Polaris 9550 Sport robot, Lamotte ColorQ Pro 7 test kit.
