Results 1 to 15 of 15
Thread: First Pool for Us - Townsville, Australia
    Sep 2015
    Australia
    11
    30 lineal metre pool, Zodiac Tri XO Magnesium Chloride Chlorinator (can be changed with push of a button to sodium chloride) - this first post is copied from a local forum, so it covers a week or so of work
    Approx 11.5m long and betweem 4 and 6m wide
    Before
    So with the dig date not to far away, i have been flat out locating our main bore water line, as well as irrigation solenoid cables that i stupidly ran massive distances, instead of actual poly pipe many years ago. The ground got soaked overnight, so digging wasn't too bad, so with all that out of the road (moved across to right of pic, along garden bed), it will be covered with fill later
    Been a massive couple of days. First job was to ditch the old bore pump shed, as this is where the pump and filter for the pool will be going as well - we will pour a new slab and build a nicer looking shed over it all. A LOT of irrigation cables, water pipes (bore, town water and rainwater), plus power (Tariff 11, T31 and T33) to all get set up before the slab is poured
    Old shed, upended to left, bore casing with pump removed in centre of pic
    Part of the fun was pulling up all the irrigation solenoid cables - put down about 9 years ago, and lots more tree roots to contend with now!
    The pool builder turned up at 6am, and we decided the final shape and location in the next 15 mins, then the digger started hooking in
    End of Day 1
    We also, dug a trench dwon the far side of the pool to run an external power point, as well as water for a poolside shower. While getting the digger to trench with his 300mm bucket was quick and nice and easy to lie pipe in a wide trench...there is a heap of dirt to push back in!
    Anyway, we are happy with how it looks now, here is a timelapse vid of the dig - pretty awesome at the end where they are starting to steel it all
    https://youtu.be/cLtklCF62dg
    Well, got home from being away, with a whopping big lump of concrete in the backyard!
    Here is the before shot of the old bore site, with the new one having the previously mentioned 3 x power tariffs, 3 x water sources, plus a heap of irrigation control cables and pool plumbing and lights
    This is a shot of it all steeled up, - end of day 3 of construction
    Start of day 4, they were into it
    The pool builder is a top bloke, and thinks its hilarious our 5 yr old wanting to get amongst it - here Lewis is getting the tick of approval!
    Finished product looking towards shallow end
    I will get a shot of the other end over the next few days.
    Just been watering the concrete down and will be another week or two before the pebbles go on
    Started framing the new shed up, as well as running power for the various tariffs. Its going to be a lot tidier than the old tin shed that used to cover the bore
    Jun 2014
    15,221
    Re: First Pool for Us - Townsville, Australia
    Great pics Rob. The little helper is awesome. You should have a nice product once it's done. Keep in touch with us, and if you have any questions about TFP pool care, let us know. Enjoy your weekend.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Welcome to TFP! That is a LOT of work in a few days! Congrats in the new pool!
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    Good to see an Oz build. They are few and far between.
    Looks like it will be a cracker once it's done.
    Can't beat the climate on Townsville.
    That shady spot you have will be perfect to float with a tinnie ot two.
    So what is the depth range? Looks sports pool style.
    40k gal freeform, IG pebblesheen, 9'x'6' raised spa, 2-1/2 hp Whisperflo, 520 sq/ft cartridge, Legend w/ booster, Intellibrite 5g in pool @ spa, Rainbow 320 Chlorinator(retired),
    Mastertemp 400k BTU, 3x3 hp Whisperflo Swimjets, 2x2 hp Whisperflow for 15ton moss rock waterfall, Intelitouch Controller, 850 sq/ft Travertine deck, Gas/Wood firepit,
    Autofill, TF-100 test kit w/ SpeedStir
    Sep 2015
    Australia
    11
    Depth is looking like 1250mm or so to a little over 1900mm. Just hope its not to deep and the deep end!
    Sep 2015
    Australia
    11
    A bit of progress happening at the moment.
    First thing though, it finally dawned on me that we had a skate bowl in our backyard...pity i can't skate!
    I also got a bobcat in and got the site all levelled. Built up soil on one side where gardens will be eastablished, and left ground level intact where we will put an exposed ag concrete path.
    The guys came out yesterday to pebble the steps. I personally didn't like the sandstone look that many people put on steps, so the builder said he always wanted to try steps with a lot more glass than normal. So we mixed the aqua and dark blue glass, along with some black and gold pebbles.
    This is then towelled on:
    Allowed to start to go off, then the top layer of mortar is sprayed off with water. On the right is the pebbles starting to show through, left is yet to be sprayed
    Finished result - not that it really sparkles with water present, looks a little duller without water.
    Also, the builder had installed rocks around the deep end, and part way up one side - i only wanted these on the side where gardens will be present, so it doesn't look like rocks just piled on top of the pool edge
    A shot looking back from the deep end
    Today i hope to get a decent chunk of the shed built, and get the electrical sorted, and the fencing guy is starting as well
    Sep 2015
    Australia
    11
    Fence is up
    Progress on pump shed is OK
    And the top colour of pebbles are on!
    Tomorrow morning the white/blue glass pebbles for the sides and bottom will go on, acid wash, then start to fill!!!
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    That is going to be beautiful!
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Aug 2015
    Plano, TX
    217
    Quote Originally Posted by pabeader View Post
    Yeah, I'm diggin' it! Great to have another Aussie on here too!
    Curtis- 20k gallon IG gunnite/plaster with hot tub/waterfall and "grotto"
    All Jandy equipment: 60sqft DE filter - 399k btu natural gas heater - Stealth pumps - iAquaLink RS8.
    Polaris 9400 on patrol.
    TF-100 in da house/TFP method in effect: FC=4-6, pH=7.5, TA=80, CH=250, CYA=50, Borate=50, CSI=-0.21
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    Coming along well.
    Look forward to seeing that pebble wave with water.
    Sep 2015
    Australia
    11
    Its been a while between updates as i haven't stopped for the last week with work and getting the pool finalised!
    This was the start of pebbling the bottom half with a mix of white pebbles and blue glass beads
    This was done in the morning, then acid washed that arvo, and start to fill straight away - was great coming home ona Friday arvo and jumping in a (very shallow) pool for the first time with the kids
    Due to the fact we have 25mm line from the street, it took around 15 hrs to fill, a bit quicker than i originally had though. Total volume is 60 000L.
    This shot was taken mid saturday morning, exactly 3 weeks after the dig
    So we got amongst it for a swim, then put all the start up chemicals in and let it circulate for a few days.
    Then pulled all the fence down, and boxed up for concrete around part of the pool
    Ran a few more power lines before we poured it, then got a couple of mates around to get concreting
    For those that haven't seen exposed aggregate done before, it is pretty awesome. After it is finished, spray with sugar and water (sugar is a concrete retardant), then hose off the top later of cement to reveal the aggregate.
    This shot shows the process part way through
    And, to the stage we are now
    Enjoyed finally going for a swim myself after the kids have been in it all week.
    And the night shot
    Looks amazing at night, with the lights reflecting off the trees around it.
    So still tossing up with robot pool cleaners, need to install the shower once the concrete goes off a bit more, as well as start on the gardens around the pool.
    Also am about 3/4 done on the new pump shed, so will update some pics later of the other bits.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    That turned out awesome! Good on ya, mate!
    dw9000's Avatar
    Aug 2014
    NW Ohio
    184
    That looks fantastic. Something you can really be proud of and enjoy with your family.
    In-ground block / vinyl liner 33' x 22' x 5',, approx 25k gals
    Cartridge Filter
    Floor drains, 2 skimmers, 3 return lines (2" plumbing ultra-flex PVC)
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,593
    what a neat and different pool!
    LOVE the guy letting your little helper work on the pool! So sweet!
    What a lot of work you have done yourself! NICE job!
    Thanks for sharing!
    Kim
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    That was a fast job and SO pretty!! Congratulations!!
    Denise-TFP Guide
    IG 13.6x30 gunite, Radiant Fusion Topaz, 3.6/5.6/4, 14100 gal, 2 skimmer, 4 Hayward LED lights (pool & spa), Hayward Echostar VSP, 2 future fire bowls, raised beam wall w/ scuppers,7x7 raised spa, DE Progrid70, SWG Hayward Goldline, OmniLogic, Hayward 400K BTU heater, stamped colored deck, Dolphin Discovery robotic cleaner, TF100 test kit, Newbie in Bixby Oklahoma
