Results 1 to 9 of 9
Thread: It happens to anyone...
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    So I have been in cruise control mode with my pool. Temps down to low 70s, solar cover on nearly all the time to limit chlorine losses. No swimming going on with school, activities and lower temps. Checking every couple days on the FC. CYA is down to 30 after starting summer at 40. Been bumping FC up to 6 when I test, usually lasts 3 days before I have to dose again. Hadn't tested/dosed since Tuesday night and haven't run the robot or brushed since then either so over lunch today I decided to roll off the solar cover and check things out as leaves are starting to blow onto the cover and a bit in the pool, especially the uncovered end step area.
    Before I take the cover off, I look at the ladder and on the top rung still in the water, a bulge of yellow-green mass is showing where the rung meets the side rail. I give it a closer look and it's algae for sure. Peek under the cover and I have some small drifts on the slope down to the deep end and a few in the shallow end on the same side as the ladder. Panic sets in but I deserved it. Then I find the reason why things probably got out of hand... a dead mouse floating under the solar cover in the deep end and smelling not so fresh...
    Brought the FC up to 14 ppm from 1.5, brushed the heck out of the ladder and algae drifts and threw in the robot. Back to work.
    Just checked the FC again and after 8 hours uncovered, lots of sun, albeit low angle fall sun here now, FC down to only 13. Think I caught things pretty early.
    OCLT tonight.
    A good reminder to test frequently and stay on top of testing and potential critter invasions this time of year.
    Isolated Spa - 345 Gallons
    Jul 2015
    Kentucky
    1,124
    Re: It happens to anyone...
    Oh Nooo that's horrible, I am so sorry. Yes, it can happen to anyone. Good luck on tonight's OCLT, I hope all goes well.
    24' Round x 4.5 ft deep AGP (15,200 Gallons), Vinyl Liner, Hayward Vari Flo XL Sand Filter- (model SP0714T1),
    TFTestkits , PoolMath , Pool School, RECOMMENDED LEVELS, SLAM & the Chlorine/CYA CHART. Support this Site! TFP Totally Rocks.
    Aug 2014
    Northern IL
    4,615
    That was quick! Visible algae? Slime, maybe. Cloudy, maybe. But gunk? That was SOME mouse! Keep 'em North!!! I just tested today for the first time since Tuesday also. Just 2ppm down. Lucky me!
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    I have a swg, and I've been super lazy testing. Like once in the last 2-3 weeks. Still dead on, and beautiful. Too bad it's cold. It warmed back up to 75 a couple days ago, and I couldn't resist one more last swim. It was a little chilly at first, but awesome. I have to find the some solar money next year. I just have to!
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,765
    I had a chipmunk AND a mouse on Thurs!
    The still-warm water seems too tempting -- water is still being heated as son (24) is having his annual birthday shindig tonight and no matter how cold the air gets, Fireball will make 'em brave!
    The upside of the crazy heat bill is that I had a lovely swim last night!
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    I had a scare earlier this week. The dog on the "on" timer for my SWG came loose. Luckily my FC was high because water temps are lower, but it was down to 3. Another day or two and it would have been SLAM time!
    Solar is awesome! Still swimming every day!
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Don't worry...we're here for you. Be sure to read Pool School and how to SLAM. Also, please post a recent full suite of tests.
    I used to find 'floating masses' in the attached spa that I would attempt to keep empty over the winter (when it used to rain out here) and every spring, I'd find 'floating masses' of something that got in there and died. I never bothered to try and figure it out but likely was frogs or newts or salamanders...something soft. We do have an enormous oak tree that is the Holiday Inn for squirrels but so far, dead squirrels have only been found in the yard and not pool!
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    Feb 2014
    Central Minnesota
    5,080
    OCLT Friday night was a 1 ppm loss. Not too bad. FC was at 9.5 ppm Saturday afternoon and the kids actually swam! 72 degree water but it was a warm, sunny day around 80.
    Saturday night was 0.5 ppm loss. Pretty good. The very faint haze that I could only see because I know what CRYSTAL clear water looks like is also gone for sure. Have not had measurable CC yet. Letting FC levels come down and now it's a race to get the pool below 60. Temps are going to be maybe 60 for a high over the next week and lows in the low 40s.
    No more mice and since I'll be leaving the solar cover off to help things cool quicker, I'll see those buggers if they do decide to take a plunge. It was a quick SLAM for sure. Happy it was so I can close soon with a clean pool.
    Jul 2015
    Kentucky
    1,124
    Well done Joel. I'm glad all went quickly.
