Results 1 to 7 of 7
Thread: Pump humming
    Sep 2015
    Alta Loma, CA
    3
    Pump humming
    Hello, I have a Intex sand filter, (SF101101), and it makes a humming noise instead of running. I have read through some forums and understand it might be my start capacitor. Does anyone here know where to buy one online? or a part number? Thanks!
    Jun 2014
    15,221
    Re: Pump humming
    Hello and welcome to TFP! I was trying to help, but couldn't pinpoint that part. Is your set-up like the Intex pump & filter combos when the filter and pump are basically together? Like this for example: 14 Sanitation - Pool Accessories - Above Ground Pools - Store - Intex The parts listing for these only went as far down as replacing the whole motor. But if this is not your type of set-up, is there any chance there is another part number on the equipment or motor itself that may help us search a little better?
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Re: Pump humming
    You need to pull the cap out, test it best you can, and then either search online or go to a motor repair place or large appliance store and see if they can match up a new cap for you. They can also verify if it is bad, too, most likely.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    Sep 2015
    Alta Loma, CA
    3
    Re: Pump humming
    Quote Originally Posted by Agent99 View Post
    I took off the top, 4 small screws, by the on/off/timer button, all I saw were wires and circuit board. Do you know where the start cap. is on the motor? Thanks!!!
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Re: Pump humming
    Does your motor have a hump on it? A picture or two could prove very helpful here...
    Some motors have the capacitor hiding inside the end where the wires go.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Sep 2015
    Alta Loma, CA
    3
    Re: Pump humming
    Here is the picture, I had the top lid off, and saw a bunch of wires. Thanks for your help.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Re: Pump humming
    I hate to say it, but I can't find any useful information about that model. Hopefully someone else will be able to help with this one.
