Thread: small debris in pipes?
    Jul 2013
    Northeast
    128
    My deck paint is chipping off and thanks to the wind small debris get in to the pool. I was curious if I something got in bottom drain pipes, but pump bucket didn't have anything. I shut off skimmers and turned the pump on. Sure enough, I got some small ones in the pump bucket. Now I wonder if pump is strong enough to get them all from the bottom drains. Is there a way to cover one of the bottom drains, so I get more pressure from the 2nd one?
    Also, what are the chances of having small particles pass through cartridge filter and get stuck in the heater?
    I use air compressor when I close my pool, but one time when cyclone blower was used I had rubber plug washer shooting out from one of the skimmers.
    Is cyclone blower a good way to try clear the bottom drains? Also, even with cyclone, the closest bottom drain was bubbling well, but the 2nd barely had any bubbles coming out.
    Is there any other way to check if the bottom drain is slightly clogged? What should the pressure gauge show if I had this issue?
    (My pressure gauge is currently broken so as the housing it's in. So, currently I don't have the readings. My filter always stayed relatively clean throughout the season, so I only wash it when I close the pool)
    Thanks
    23k in-ground plaster. Cartridge filter Hayward 450 or 550. Hayward 2ph pump.
    liquid chlorine, tablets occasionally when out of liquid and cya allows it. ph down.
    stabilizer (Had no cya last two openings, but never before that)
    no other chemicals used in years
    TF100.
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Re: small debris in pipes?
    Most cartridge filters will catch anything 1 micron or larger so that should be quite sufficient for paint chips.
    You could brush the debris closer to the MD with the most suction and see if that works.
    I am not familiar with cyclone blowers but I get the gist of them. There are many ways to check for clogged pipes: run a hose turn on down the pipe, electrician's tape, plumber's snake.
    I recommend the nice glycerin-filled gauge that tftestkits.net sells. It is a really nice gauge for a good price.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    Jul 2013
    Northeast
    128
    Quote Originally Posted by Agent99 View Post
    that is what I am afraid to do - I'm afraid the pump is not strong enough to lift up the debris from bottom drain pipes.
    that's why I wonder if there is a way to temporarily seal one on the bottom drains hoping the suction will be stronger this way
    Also I wonder if using cyclone blower would blow debris out of the pipes back in the pool
    TF100.
