Results 1 to 17 of 17
Thread: The Pool Nerd in Me made me do it.....
    JoyfulNoise's Avatar
    May 2015
    13,176
    The wife thinks my pool chemistry-toy habits are in need of an intervention....but I just HAD to have it -
    I told her I bought it because I love her and only want the very best pool for her and the kids to swim in....apparently she would prefer I save up and buy her the sparkly tennis bracelet instead
    PS - To all my fellow testing nerds, two things - (1) it dispenses slightly more powder than two scoops from the blue spoon so it uses powder reagent a little quicker, and (2) it only fits powder bottles that are supplied by Taylor (like the one in the photo). Unfortunately it will not work with the standard bottle found in the TF-100's.
    Matt
    Jun 2014
    15,008
    Re: The Pool Nerd in Me made me do it.....
    I use the TF-100, so I can't take advantage of the dispenser, but my "tackle box" is just a bit nerdy as well. I think most of us here are when it comes to testing.
    Jun 2015
    Phoenix, AZ
    216
    Why do you use two scoops per test? I am using one scoop only for every test..
    Should I be using two scoops?
    2015 build (link)| 16.5 K gal | Salt Water | IG rect | 35'x16' | 568 sf | 105 ft peri | depth 3'-5' | PV3 in-floor | 2 Venturi skimmers | MDX+SDX drains | T-CELL-15 SWG | Hayward Ecostar VS pump | Hayward 7220 DE Filter | Aqua Cal Icebreaker Heat / Cool pump SQ166 | Hayward Sense & Dispense PH Controller| Omnilogic | Pebble Sheen Blue Surf | Ultra UV | Stenner acid pump | Coverstar Automatic | TF-100
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    1 heaping scoop is what I use for each test. More than sufficient for the 10 mL FC test. As long as you have a little undissolved R-0870 in the sample when it's mixed, that's enough.
    Isolated Spa - 345 Gallons
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    My advice is try it both ways and decide what you think. The 'official' instructions say 2. Most folks find that 1 heaping works fine.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jan 2012
    'burbs of Augusta, Georgia
    7,264
    Either one heaping scoop or two level scoops are appropriate
    May 2015
    13,176
    You have to test it for your specific testing regime. Some can get away with one big scoop, others do it with two. It is important to know this - the test works correctly when the indicator dye is over saturated relative to the chlorine. The test will be off if you don't get all of the chlorine bound to the DPD indicator.
    I have lots of powder and I test all the time so I'm not stingy with reagent.
    Matt
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    575
    Guess I need to "HEAP" up a little more then!
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Is that an ancient washing machine in the background there?
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,734
    I just bought one...what does that make me?
    I've always felt a little odd holding that microscopic spoon
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    May 2015
    13,176
    Quote Originally Posted by Agent99 View Post
    It's actually a high efficiency low water use Maytag BravoXL (no agitator). Works much better than the piece of junk LG front loader that came with the house, uses less water and can wash my California king size comforter with ease. I will never buy a front loading washing machine as the MTBF rates of the rotary shafts are abysmal compared to top loaders. I have owned this machine for three (3) so far and it has never needed anything on it serviced.
    But I'm not tooting my horn or anything
    Matt
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,411
    THAT is my dream washing machine! Oh to be able to wash the dog and cat beds in ONE cycle! Oh and our comforter with ease! LOL
    Matt I bet Mom LOVES it for all of the boy's jeans and such!
    Kim
    May 2015
    13,176
    Quote Originally Posted by kimkats View Post
    Kim
    Two adults + three boys = Bravo runs daily from Mon-Sat And they are not even teenagers yet!!!
    Matt
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    LOL...looked kinda old with that gold finish and a ton of buttons and such. I have a Maytag Neptune front loader. Gosh, it must be going on 14-15 years old along with its cousin gas dryer. I like Maytag but we had issues with a refrigerator that we bought right along with the washer/dryer so thumbs up on the W&D, thumbs down on the R.
    ----Chris----
    May 2015
    13,176
    Yeah, I can see how it looked old school. As you see from the thread, my family and washing needs are quite high so front loaders just can't do the job for me. Plus I was happy to get rid of the LG electric dryer and buy the gas fired dryer along with the top load washer. Gas is much cheaper for me.
    Good to know about the fridge!! We're probably looking at a new fridge purchase in the next couple years so I'll keep the Maytag experience in the back of my mind. Of course, if had my dreams come true, it would be a Viking or Sub-Zero fridge built in to match the cabinets....somehow dropping $15k-$20k on a fridge seems wrong to me.....
    Matt
    Aug 2015
    Plano, TX
    217
    I thought it was an old stereo amplifier at first glance. My wife is so annoyed by my love for chemistry. I've had to make so many apologies over the years for all of the equipment in my brewing lab. She wasn't even phased when I bought "this new awesome pool test kit" that I just had to have.
    Curtis- 20k gallon IG gunnite/plaster with hot tub/waterfall and "grotto"
    All Jandy equipment: 60sqft DE filter - 399k btu natural gas heater - Stealth pumps - iAquaLink RS8.
    Polaris 9400 on patrol.
    TF-100 in da house/TFP method in effect: FC=4-6, pH=7.5, TA=80, CH=250, CYA=50, Borate=50, CSI=-0.21
    Jul 2012
    Tallahassee, FL
    30,411
    BUT I bet she LOVES the clear pool to swim in while sipping on some of your brew!!!
    Kim
