Thread: Is your pool equipment covered?
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    I had to read my owners manual due to a "no flow" error on my Jandy Aquapure when I noticed it stated that the equipment had to be covered (sheltered) or it would void the warranty. My builder put the pad on the side of the house but never mentioned this. I was curious as to how many people have their equipment under shelter. When I called Jandy support they never asked about it. Does it make a huge difference in life expectancy?
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Re: Is your pool equipment covered?
    I have all my equipment in a plastic Lifetime shed but that was a recent event this year due to the pool/backyard remodel. Before that, all the equipment had been outside since, well, 1978.
    I would think it is an improvement to shelter the equipment if possible but if you read up on your pump or filter, they likely say that they are designed to be outdoors under the stars.
    I sheltered my stuff because I don't want to look at it and it provided storage of general pool stuff. The electronics are also sheltered...just feels better that way to me.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    Sep 2013
    Charleston, SC
    538
    My pool equipment is also covered. I don't like to look at it, plus it cuts down on noise and I also like the added protection from the salt air being coastal.
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
    Oct 2012
    604
    Thanks for the responses. I should note that it was the pump owners manual that stated this. I am going to go check the SWCG manual to see what it says. I doubt the filter would be included due to clearance issues.
    Oct 2012
    604
    Ok, I must be crazy. The wife and I just went through the pump owners manual and we cannot find it. There is a statement that states "Do not install within an outdoor enclosure or beneath the skirt of a hot tub" which we both remember seeing but we cant find anything about sheltering the pump motor.
