Thread: Conversion back to chlorine in progress
    Sep 2015
    Brenham Texas
    3
    I started thread a few weeks ago - don't know how to find it .... So...
    Here goes again
    above ground 15,000 gallon pool -trees around half of pool ...
    Switching from Baquil to chlorine - I waited a few weeks - I ordered testing kit - started adding bleach about 2 weeks ago ... Sorry no pretty colors just dark green pool water - no photos - The swamp monster would have been at home .... Now 25+ gallons bleach later - we can see the bottom again - fairly clear - still green tint to the water.
    I took test readings for the first time this am ... Felt very intimidated by the kit when it arrived... So just used blue box ...which gave me cl 5 be 10. (Pool was dark/green). I kept adding bleach. Ph between 7.8 and 7.2 ( I would add soda ash to 7.8 level)
    I havent taken blue box test this week . But decided to breath deep and follow the directions for all the tests ...
    But now I don't know what to do with them😉
    9/25/15 pool test results
    Chlorine drop
    CF
    33 drops x .05 = 16.5 ppmCC
    4 x 0.5 = 2
    TC = 18.5
    Calcium hardness test (250-400)
    3 x 25= 75
    Total Alkalinity test (100-120)
    9 x 10 = 90
    CYA test (40-50)
    20
    I had added 2 cups soda ash yesterday .
    Thats all all I know about adding : soda ash and bleach( we also have 3" chlorine tablets - I have two in skimmer.
    Any suggestions?
    [COLOR=rgba(0, 0, 0, 0.701961)]
    [/COLOR]
    [COLOR=rgba(0, 0, 0, 0.701961)][/COLOR]
    [/COLOR]
    Photos didn't insert in earlier post
    ​JAKS
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Re: Conversion back to chlorine in progress
    Here you are: Wanting to convert back to chlorine ..
    Hopefully someone with more experience doing the conversion will be along soon.
    From what I read on the conversion article, you really don't' need to do anything but keep putting bleach in until you keep a steady amount. Some things to note: pH tests wrong when FC is above 10. So you should not be adjusting based on those readings. As far as I can tell, all you should be doing is adding bleach and testing often.
    Link to the article: Pool School - Convert Your Baqua Pool to Chlorine
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    domct203's Avatar
    Jun 2015
    CT
    3,596
    Welcome to the forum.
    Just be sure to to follow the conversion instructions exactly. You need to maintain a FC of 15ppm, the more you test and add chlorine to get to 15-17ppm the better.
    Remove any chlorine tablets from the pool. The tablets will add CYA to the pool and you are not yet at that stage of the conversion.
    It it is very important that you test/add chlorine often to maintain the proper FC level. Once a day testing/adding is going to prolong the conversion, especially in the early stages of the conversion.
    Good luck, ask questions if you are not sure of something.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,014
    Hi Jaks,
    just focus on your Chlorine Level and maintain that. Hi FC and skew the accuracy of some of the other tests, especially pH. So dont worry about balancing anything until your coversion is complete.
    Its complete when
    your water is clear
    your CC's are .5 or less (one drop to go clear)
    You pass the overnight chlorine loss test (not more than 1ppm FC lost overinight).
    Also, just to mention, on the Blue Box test. Chlorine can only be measured to 5.
    The scale which goes up to 10 is for testing the Bromine level.
    Divin Dave,
