Results 1 to 7 of 7
Thread: Best way to get last few inches of water out of Intex AGP
    Jun 2012
    Michigan
    154
    I have an Intex AGP, drained it with a hose through the drain plug, but there's still a few inches of water in the bottom. What's the best way, or at least some options, to get that last bit of water out of the bottom? Last year i held one end of the pool as high as I could to help push the water to the side with the drain plug open, and it was a miserable experience and took forever haha
    Intex 16x48 UltraFrame AGP, included filter pump
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Best way to get last few inches of water out of Intex AGP
    Have a shop vac or one you can borrow from a neighbor? Just take the filter out of it before sucking water...
    Isolated Spa - 345 Gallons
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,557
    Shop vac
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Jun 2012
    Michigan
    154
    So far sounds like I'm going to buy a shop vac today
    Feb 2014
    Central Minnesota
    5,080
    They can also come in handy for blowing water out of lines when you winterize. My Rigid brand from HD has lasted quite a while, it's a 6.5 HP that you can also take the motor assembly off and use as a leaf blower.
    Jul 2014
    Oakbank, Canada
    389
    I just used a scoop I made from a plastic jug, and a 5 gallon pail. Took me less than an hour to get it all out, and then used towels to soak up the rest (kept wringing them out). Cost me nothing but a little work and time.
    I just found that the shop vac hose was too short and I did not want the entire shop vac in the pool with me just in case....
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    philc's Avatar
    Jul 2015
    Grand Island Nebraska
    190
    I picked up a small 110v pump. It will draw down to 1/8" of water. Shop vacuumed the rest.
    http://www.tractorsupply.com/tsc/pro...y-pump-1-12-hp
    Intex 22' X 52" Ultra Frame AGP ( 12K gallons) , Intex 633T 2500 GPH (41 GPM) running Doughboy Silica II sand filter (16"dia. 1.4 ' S.A.) ( And doing it quite well, I might add!) Hayward through the wall skimmer, TF100 with Speed Stir. Hard plumbed, Intex fountain ...........
