Results 1 to 7 of 7
Thread: Triton TR60
    Jul 2015
    Abilene, TX
    6
    Triton TR60
    Hello. I bought a new Pentair Triton TR60 for my pool. I've plumbed it and all is well, no leaks, pump primes, pump well stays full, flow is good. I have a nagging feeling that I didn't lift up the diffuser when I put the lid on it. I assume the diffuser can de rotated because I read somewhere it could. I can't get the lid off to check. Has anyone had this problem too? Any tricks for removing a stuck lid? Also, pressure reads 8-10 psi while priming, but then drops to zero when filtering under none prime conditions. Any thoughts?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Triton TR60
    Do you still have the wrench that goes on the top to remove it? If not, you may have to use a strap wrench large enough to go around the top.
    What are your pump RPM settings at prime and during normal operation? I'm assuming you have a variable speed pump that's running at lower RPMs during normal operation.
    Isolated Spa - 345 Gallons
    Jun 2015
    Wildomar, California
    423
    Re: Triton TR60
    You need the plastic wrench that comes with the filter. You should contact the place where you purchased the filter and have them get you one. Or, find it online.
    Jul 2015
    Abilene, TX
    6
    Re: Triton TR60
    I have the plastic wrench. The lid won't budge.
    3050 at prime. Runs at 2350 while I'm trying to clear pool of green.
    Jul 2015
    Central Valley CA
    1,109
    Re: Triton TR60
    Try pouring warm to hot water over the lid and tank then cool just the lid with an ice cube. I do something similar all the time with threaded metal pipes and a torch doubt it will work on PVC or what ever the lid is made of but worth a try.
    Re: Triton TR60
    Try opening the air relief and wait for the pressure to equalize. If necessary, you can use a short length of pvc pipe to extend the handles on the lid wrench.
    Support the site
    Jul 2015
    Abilene, TX
    6
    Re: Triton TR60
    I'll try both. Thanks!
