Good Idea To SLAM Periodically ??
Do you take Tums even if your stomach is not burning?
My plan is to go without ever SLAMming by paying attention to my FC, pH and CYA.
If your water is clean and clear then a periodic SLAM makes no sense. You would simply be raising you pool water up to shock level and passing the overnight chlorine loss criterion right away. It would simply be a waste of bleach which would add unnecessary amounts of salt and lye to your pool water. You would also use more acid since a SLAM requires a drop in pH first. It's really nothing more than a waste of money, time and testing reagents.
Ten years now, never have Shocked or SLAMed my pool. It is a treatment for a problem. If you don't have the problem, you don't need the treatment
