Hi all,
We finally decided to build our pool and have been working with 2 PBs who seems to have great reputation in our neighborhood. We have made up our mind to go with the PB who has been very responsive and eager to get our business.
Below are the details and pictures. What do you folks think? We are not building a spa, but instead decided to get a heater to heat the pool. Also, what payment terms should we agree to from the PB. it seems like they want 1/3 and last payment due at plaster.
The cost of the pool is coming out to be around $70k.
Design Stats:
Pool: 438 s.f. / 100’ Per.
30’ x 20’ 6”; 3’ 6” to 5’ deep
Summary Pool Details)
Excavation:
o Trac excavation + Bobcat shuttle (Left side yard)
o 7 hours of excavation
o (Remove existing flagstone deck- 363 SF)
o Form equipment pad
o Hand shaped walls, tanning ledge, steps benches and corners
Steel:
o 10” x 10” grid of 1/2” steel in walls, floor, footers and equipment pad
o 4 Bar box beam with #4, 1/2” steel around top edge of shell
Gunite:
o Pneumatically applied, 6 sack mix
o 2 Benches/Swimouts
o (1) Tanning ledge with 6” of water
o Full gunite equipment pad
Plumbing:
o Hand dug trenches with lines laid out flat to minimize settling over time.
o All connections made using commercial grade, gray PVC glue with 45* and/or 90* connectors only- NO HEAT AND BEND
Equipment:
o Pro-Edge dealer warranty of 3 years, including parts and labor
o Main circulation pump: Jandy 2.0 HP; 2-Speed pump
o Jandy high-flow, commercial grade cartridge filter
o Polaris 280 with dedicated ¾ HP Booster pump
o (3) Savi Melody “J” series color changing LED lights
o AcquaPure Jandy Salt System
o Jandy RS-P4 + iAqualink (iPhone/Android) interface
o Jandy never lube, maintenance free pool valves
o Brass or Aluminum skimmer lids, available in round or square.
o AquaComfort ACT-1250/HC Electric Heat/Cool Pump
o Paramount In-Floor cleaning system powered by Jandy 1.0 HP Stealth plump
o 12” Raised stone fire pit- built up off gunite footer out of mason block,Capped and veneered with stone to match pool. Includes: permitting, Gas run, ss burner and fire pit screen and glass media
Tile:
o 138 feet of standard cost, “6” x 6” or 1” x 1” ceramic tile for pool and spa water line and back water feature wall
§ Smaller or glass tiles available at additional cost
Stonework:
o Hand selected and chiseled natural stone, 2” thick, for pool, water feature wall and column cap: Leuders Limestone, Oklahoma Flagstone or Silvermist
o Hand cut and chiseled Oklahoma Flagstone veneer- Ashlar Pattern: raised columns and water feature all
o (3) 12” hand-made stone scupper; to match coping material: Oklahoma Flagstone, Leuders Limestone or Silvermist
· Decking:
o 794 SF of Tier #2 concrete pavers
o Lifetime product warranty- 5 year installation warranty
o Laid over a 6” bed of ¼” gravel, decomposed granite and cushion sand
o 4” Brass drain caps with network of 4” PVC drain system under decking
· Interior Finish:
o Standard- Crystal Pebble (Blue Granite or Blue Ice)
§ Other finished available at additional cost in the options section
· Yard Repair:
o After decks pool site will be graded out with 1 load of select fill soil
o Take down fence during excavation and re hang after grading is completed; bring gates to code
o (4) pallets of Bermuda sod and (4) sprinkler zones
Warranties:
· Structure Warranty: Lifetime
· Masonry Stone Warranty: 1 year
· PVC Plumbing Warranty: 1 year
· Belgard Product Warranty: Lifetime
· Pebble Warranty: 10 years
· Zodiac/Jandy Equipment Warranty: 3 years
· Paver Decks Warranty: 5 years
· Polaris Cleaner Warranty: 3 years
· Polaris Pump Warranty: 3 years
Design Stats:
Excavation:
Steel:
Gunite:
Plumbing:
Equipment:
Tile:
Stonework:
· Decking:
· Interior Finish:
· Yard Repair:
Warranties:
