Thread: New Owner Builder in Riverside, Ca.
    FOX MULDER's Avatar
    Sep 2015
    CORONA CALIFORNIA
    13
    Hi all,
    My name is Oscar I live in Riverside Ca. Im currently in the process of
    Building a pool I will be an owner builder
    I am looking for ideas, advice, suggestions from other pool owners on my design and plan
    POOL
    38X18
    18 36 7 DEPTH
    2 SKIMMERS
    6 RETURNS
    INTERIOR FINISH PABBLE
    SPA
    8 DIAMETER
    DEPTH 42
    I NEED ADVICE ON PLUMBING AND EQUIPMENT
    SWG SYSTEM POOL
    AUTOMATION PENTAIR EASY TOUCH
    SWG INTELLICHLOR IC 60
    PENTAIR 188594 quad D.E. Cartridge style filter 100sf 160 GMP ug
    POOL PUMP PENTAIR INTELLIFLO VS 011018
    SPA /PUMP PENTAIR INTELLIFLO 1.5 HP 011514
    WATER FEATURES PUMP PENTAIR WISPERFLOW 011513 1 HP
    PENTAIR HEATER 400K
    ANYTHING YOU RECOMMEND CHANGING?
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    Re: New Owner Builder in Riverside, Ca.
    Your equipment looks good. If you really wanted to you could get rid of the spa pump and just use the pool pump for the spa as well (unless the spa is not connected with the pool).
    More specifics and a picture of the layout would be beneficial for additional advice.
    I too am in Riverside
    FOX MULDER's Avatar
    Sep 2015
    CORONA CALIFORNIA
    13
    Thank you bdavis 466, what kind of skimmers should I get? any brand or any kind in particular are there any better than others?
    thank you
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    I like the pentair admirals because they have a circular weir as opposed to the doors that bang around on most others. Waterway also makes a quality skimmer.
    Regardless of the brand, I'd run at least 2.5" pipe from each skimmer to the pad (separately) and do not tie the main drain to the skimmer, have the MD on its own run to the pad as well.
    Are you using a pool company or are you building it yourself?
    FOX MULDER's Avatar
    Sep 2015
    CORONA CALIFORNIA
    13
    Thank you!
    I will look into those skimmers, I'm building it myself OB
    Jun 2015
    Wildomar, California
    423
    Success too you and your pool build! I live down the I15 by Lake Elsinore.
