Results 1 to 9 of 9
Thread: Muriatic Acid to Lower PH
    Jul 2015
    Charter Oak, California
    273
    I read a couple posts about the irritating smell of Muriatic Acid but never noticed it. I also had difficulty lowering my PH with the acid i purchased. Looked in the Taylor Kits reference guide for adding chemicals and thought I was adding the correct amount for my size pool. Putting two and two together I noticed that the Taylor reference guide was using Muriatic Acid at 30% while the acid I purchased was only 15%. Thats why the acid I'm using isn't particularly irtitating I suppose. At half strength, I've been adding half the amount of chemical I should have. Does that make sense? Correct me if I sound a bit goofy.
    Bob (AKA Schnozz)
    12 x 24 x 52 Intex Ultra Frame AGP, 8600 Gal; Pentair 2HP/2SP 150sqft Cartridge Filter; Hayward Through Wall Skimmer; Intex Automatic Cleaner (Fantastic); K-2006 Test Kit; Start-up 07/30/2015. First Time Pool Owner in SoCal.
    Jun 2014
    15,255
    Re: Muriatic Acid to Lower PH
    Makes perfect sense. A lower percentage would reduce pH slower and require twice as much to hit your goal.
    Jul 2014
    Sacramento, CA
    241
    Not goofy at all; makes perfect sense.
    That's actually why folks here prefer the calculator on this site (http://www.troublefreepool.com/calc.html), as it has dropdowns next to each chemical for the concentration, and adjusts the amounts to match.
    It's always good to verify the ingredients/contents of what you're putting in. In this case, putting in lower concentration than expected isn't an issue (if you test regularly, it just meant you had to add more often), putting in a higher concentration might have.
    Irritation from MA can also depend on how you handle it and the direction of wind. I recently converted from pouring in to a measuring cup then the pool, to pouring it into the pool directly, after doing it in the dark one night with a headlamp and *seeing* the fumes rising from the measuring cup. I marked a stick so I can transfer 1/4, 1/2, 3/4 jug levels onto each jug, then use that to gauge.
    21000gal IG plaster, Sacramento CA area (late 1950s/early 60s)
    Filter: Cartridge, Pentair CCP420 (2014)
    Main pump: Pentair IntelliFlo VS (2015)
    Boost pump: 3/4hp (2011), Polaris 280 cleaner (unknown age)
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,638
    VERY common! Some people buy the 15% just to help with the vapors.
    Kim
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    I still dump my MA into 5-gal bucket filled 3/4ers with pool water and then dump that in while standing on the diving board in a sweeping arc.
    Just pour slowly and concentrate a bit and it is no big deal to handle MA. Yeah, occasionally I'll get a blast of the fumes but that is when I'm rushing or not focusing.
    Quote Originally Posted by kimkats View Post
    Kim
    In my area, HD and Lowe's sells14.5% MA for $11 for 2 gallons. Leslie's sells 30.45% MA for $13 for 2 gallons.
    I haven't really noticed the difference in using either one save for the amount I use and my pool bank account.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    Jul 2012
    Tallahassee, FL
    30,638
    If you have asthma or lung/breathing problems the 15% is the way to go. Yeah it costs more but.......for some it is worth it.
    Kim
    wjr75's Avatar
    Jun 2013
    IL
    836
    I hold my breath and wear sun glasses when dumping the nasty stuff! Don't get any on the concrete unless you like orange stains. I saw one thread that if you dump pool water on the concrete around the edge prior to where you will dump the acid if any spilling happens it won't etch.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Jul 2015
    273
    Thanks for responding to such a newbie question. I really appreciate the time you guys take to offer your support..
    Bob
    Bob (AKA Schnozz)
    Gregory C's Avatar
    Jul 2015
    Central Indiana
    33
    Quote Originally Posted by Schnozz View Post
    Bob
    I am curious as to your T/A level...as this has a direct affect on your pH.
    I use the 15% as well as it seems to be the only choice in my area.
    I have always had great luck using Muriatic Acid. Always use extreme caution when using this stuff as it is quite nasty. My application method is to fill a (1) gallon plant watering bucket with a spout at 50% full of water and then slowly fill with 50% acid and then slowly pour as you walk around your pool.
    It works great for me as the alkaline level of the water that I use out of the ground (dedicated well for yard and pool) is about 360 ppm - which is quite high. Muriatic Acid seems to be most efficient in bringing the T/A down.
    In my case - I don't even look at the pH until I am able to bring the T/A down to acceptable levels due to false readings because of the high T/A. Typically I can only get the T/A down to about 105 ppm and this gives me a consistent pH level of 7.3 - 7.4 the majority of the time - barring excessive pool usage and rain storms.
    In ground rectangle pool / 20' x 40' / Fresh Water / GLI vinyl liner (replaced July 2014) / 33,271 gallons & 9 ounces / Hayward Sand Filter Model S - 200 / Hayward Super Pump 1.50 HP (replaced July 2015) TF 50 test kit
