Thread: Equipment distance from pool
    Mar 2009
    Flower Mound, TX
    2
    New guy here... Sorry if this has been covered, but I could not find it by searching. We are designing a new pool and have a couple of options on the equipment location. Does the distance from the pool/spa substantially impact the heater efficiency? We could get it 20' from the spa, but a more desirable place is about 60' from the spa. One company that quoted the pool seemed to think it was important and another said it does not really matter because the lines are buried anyway. I would appreciate any thoughts.
    18X38 Grecian 26000 gallon In Ground Vinyl. Goldline AuqaRite SWG with a 1.5 HP Pentair Pump. Triton 2 Sand Filter Two main drains with 4 main returns with 2 more returns on the swimout and two skimmers. Polaris 380
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Equipment distance from pool
    Try this thread, see if it has anything helpful you can use.
    It's all a bit over my head.
    hydraulics-101-have-you-lost-your-head-t915.html
    Welcome!
    Welcome to TFP!
    60 feet is alright as long as you use appropriately large pipes. Some extra heat will be lost through the pipes, but it won't make a significant difference.
    Mar 2009
    Flower Mound, TX
    2
    Thanks so much for the quick reply.... and Happy Easter!
