Results 1 to 15 of 15
Thread: About to run pump first time in months....ok to prime then backwash before filter?
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    Just got my liner in yesterday. return jets & skimmer have been trimmed and refitted, filling to water line now.
    The sand filter site glass has green water in it. It was clear 2 months ago when I first looked at this home
    for buying.
    I'm assuming the water inside the filter is green as well now (has not run since the old liner failed in june this year)
    I would prefer not to have any of that enter my fresh fill.
    Once I reach the pool fill line at the skimmer, can I just prime the pump basket with a bucket of water to make sure it's full, close it up, then rotate
    to backwash and switch it on? (do that first to clear all the gunk out before running it on filter?)
    Dolphin E10 Cleaning Robot.
    30,403
    Re: About to run pump first time in months....ok to prime then backwash before filter
    Not necessarily. Algae needs sunlight to grow and thrive. You can do what you are contemplating but I would just put it in "filter" position if it were my pool
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    I assume you're going to be putting chlorine in your pool right away so even if there are green meanies in there it shouldn't matter.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    ok thanks guys.
    it should be to the fill line in within the next 6 hours.
    CYA in a sock going in immediately and some bleach.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,410
    I am SO happy for you! It is really happening! What an interesting ride you have been on this year. I can hear the smile in your posts!
    NOW go change your pic! Get rid of that old thing! LOL
    Kim
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    haha Kim! And you were the first to know!
    Life is great!
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Actually, there are forms of algae that can grow in the dark. They use sugar and starch as an energy source. It is called heterotrophic growth.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    30,403
    So, should we be allowing for that in our pool filters and backwash first as borjis is asking?
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    Almost filled to the skimmer. I think I will backwash first anyways...filter has not ran since june and I don't know
    when previous owner last did it.
    plus I need to know what the "reset" psi is supposed to be after back washing and rinsing.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    It's running. came out a bit cloudy. did the backwash and rinse.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Sweet, you're on your way now!!
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    duraleigh, your recommendation to just run the pump for awhile first was a better idea than backwashing first.
    The filter had sat for months not being ran since the liner had failed.
    When I tried to do the backwash first, I did notice something about it not quite working. There should have been a lot more water coming out the waste line.
    After running the pump on filter for over 8 hours within 2 days, I did the backwash yesterday and WAY more water was coming out and the sight glass was showing brown/dirty water. After running for 3 minutes then rinsing it was nice and clear and I'm pretty sure my return jets got a big boost.
    I think it needed to be running in filter like you said to at least get the water all through the clumped up sand that had been sitting.
    domct203's Avatar
    Jun 2015
    CT
    3,577
    Have you considered deep cleaning the sand?
    http://www.troublefreepool.com/threa...-a-Sand-Filter
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Jul 2012
    Tallahassee, FL
    30,410
    borjis that is good info to know for future people needing help.
    I would also think about what Dom has said. A good deep clean.
    Kim
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    i will deep clean...on my Todo list.
