Thread: pump issues(humming)
    Sep 2015
    NewYork
    7
    Hi all,
    I have a 20 x 40 in-ground pool,
    The pump a 1 1/2 hp pent-air(centurion), just stop working...well
    it hums but no draw, it took everything apart, cleaned it it and spun the impeller( moved freely)
    Reconnected everything and it worked fine for 24hrs of continuous use, put it on backwash and it stopped working again...
    Do you think the motor maybe shoot??? or could it simply be the capacitor......
    If i leave it humming it will shoot off completely until it cools down......????
    Appreciate any feed back before i lay out for a new pump, especially since i'm getting ready to close the pool...
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: pump issues(humming)
    Classic starting capacitor symptoms. Should be a simple repair. Just make sure it's the same uF and volts.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Sep 2015
    NewYork
    7
    Thank you, will not you know how it works out.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    And please be careful! We want you back, in one piece!
