Page 1 of 3 123 LastLast
Results 1 to 20 of 42
Thread: How do you like your STEAK?
    Aug 2015
    Plano, TX
    217
    Just out of curiosity...
    How does everyone prefer their steak? We are talking cow only here! What's your preferred cut? Method of preparation? Method of cooking? From the steakhouse down the road doesn't count!
    My personal favorite:
    USDA Prime grade NY strip, dry aged 28 days, cut 45mm thick
    Natural lump oak charcoal with a chimney starter, no lighter fluid
    Let steak rest at room temp for 1 hour. Seasoned liberally with ONLY kosher salt and fresh ground Malabar black pepper
    Old school cheap-o square grill, when coals are red hot, pour in. Usually around 1400 degrees F
    Grate all the way down, 4 minutes on each side take it to somewhere between rare and med. rare
    Rest for 5 minutes, then devour!
    Curtis- 20k gallon IG gunnite/plaster with hot tub/waterfall and "grotto"
    All Jandy equipment: 60sqft DE filter - 399k btu natural gas heater - Stealth pumps - iAquaLink RS8.
    Polaris 9400 on patrol.
    TF-100 in da house/TFP method in effect: FC=4-6, pH=7.5, TA=80, CH=250, CYA=50, Borate=50, CSI=-0.21
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: How do you like your STEAK?
    Sounds the same as my favorite recipe. Really wouldn't change a thing. Maybe just a little thinner cut. I've tried all sorts of seasonings and rubs but I always come back to the basics as my favorite steak.
    Burgers on the other hand... I like to mix in a nice blend of spices such as onion powder, garlic powder, ground mustard, paprika and cayenne and then for saltiness I either go with kosher salt, worcestershire sauce or soy sauce.
    Isolated Spa - 345 Gallons
    canpool's Avatar
    Jul 2013
    Canada
    41
    curious .. Do you age them yourself or have a place that you buy @ locally?
    Kafko 15x28 Rectangle granite grey liner pool - Kafko 8 foot granite grey steps / Kafko 8 foot granite grey sunledge - Hayward Equipment - Kafko Safety Cover - Beachcomber 750 hot tub
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    medium rare. pink on the inside, just barely red at the core
    Dolphin E10 Cleaning Robot.
    Aug 2015
    Plano, TX
    217
    I usually buy my meat at Central Market. Sometimes they will have dry aged meat but if not, then I do it myself but in that case I have to buy the whole end of the rib roast and slice it after aging.
    Aug 2015
    Plano, TX
    217
    JVTrain: That sounds like a good seasoning mix for burgers. When it comes to salt on burgers, I usually use Alaea salt. It has a slight iron oxide taste that would probably work well with your mix.
    JoyfulNoise's Avatar
    May 2015
    13,173
    Go to Serious Eats. It's the only website for scientifically cooked beef. J. Kenji Lopez-Alt is a master with beef. I did his bone-in prime rib of beef recipe for Christmas dinner and it was absolutely a smash hit. Only place that has ever distinguished between Maillard reactions and caramelization (they are not the same thing).
    Matt
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Filet. 1-1/2" to 2" Warm through, no seasoning. No sauce.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    May 2015
    13,173
    I did not answer the question, so here it goes -
    Bone-in ribeye, 1" thick, salt & pepper only, gas grilled to med.
    OR
    Tri-tip with fat-cap, liberally seasoned with SusieQ's Santa Maria style dry-rub and slow roasted @250F on my Big Green Egg smoker (hardwood charcoal, never briquettes!) until 140F internal temp on Bluetooth remote thermometer.
    Matt
    Aug 2015
    Plano, TX
    217
    Wow that tri tip sounds amazing
    May 2015
    13,173
    Quote Originally Posted by Ale_Brewer View Post
    It's a roughly 8hr smoke depending on the weight of the tri-tip. I can put up to 3 tri-tips in my XL smoker at once so I usually roast one for my neighbor and just ask him for reimbursement on the meat.
    It literally melts in your mouth. I slice it thin and use it for sandwiches.
    Matt
    Aug 2015
    Plano, TX
    217
    I'll be driving through Tucson next year so I'll swing by for a sample!
    May 2015
    13,173
    Anytime....the recipe comes from a local guy here who has a trailer rig that he pulls around to parking lots. His BBQ grill is literal the size of a landscapers trailer with a metal grate and he uses mesquite tree trunks as logs. He cooks 30-50 tri-tips at a time and sells them for $28-$30 per roast. When he's cooking the smoke attracts people from miles away.
    He calls his rig BBQ-4-U.
    Matt
    May 2015
    13,173
    My next endeavor - Lomo al Trapo
    I tried doing this once a long time ago in the oven with a beef roast encased in a paste of kosher salt and water (2 lbs of salt and 1/4cup of water, just enough to make a paste) but I cooked it too long in the oven and it was like dried beef-jerky.
    Matt
    Aug 2015
    Plano, TX
    217
    Nice! I am going to do that on my next camping trip in a few weeks.
    May 2015
    13,173
    I was inspired to grille steaks today by this thread -
    Some filets and NY strip steaks with some grilled baby squash and baby red potatoes. I like to pressure cook the taters for 4mins prior to greasing them up and roasting them on the grille.
    Gonna eat gooooooood tonight!!
    Matt
    May 2015
    13,173
    Oh yeah!!!!
    Matt
    Aug 2015
    Plano, TX
    217
    Oh man that looks awesome! I had a dinky lil pork chop for dinner. Eating healthy sux
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Beef is healthy. It eats vegetables and other stuff like that.
  20. Back To Top    #20
    May 2015
    13,173
    Quote Originally Posted by pabeader View Post
    Beer spit through nose!!!
    LOL & ROFL!!
    That gets you a steak dinner next time you're in Tucson
    Matt
